bios dump elitebook 840 g3
  • xzm
    • Feb 2011
    • 28
    #61
    Re: I need a bios and ec dump for 840 G3
    Please for unlock bios password for 840 G3. I uploaded here locked dump in attach '840 G3 locked.rar'. Thank you in advance.
    • ssspunkyyy
      • Jun 2018
      • 3
      • Norway
      #62
      Re: HP Elite book 840 G3 need bios urgently
      Originally posted by imranromi
      Post complete file need 16mb.Use bios programmer and save.
      Ah, so you need the bios dump. Well, unfortunately for me, I don't have a programmer..
      Any other options?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        #63
        Re: bios dump elitebook 840 g3
        Try this and reply i try new methods.
        Thank you very much. I just unlocked a 840 G3 myself with this file, it worked perfectly.
        I did clean the ME before flashing. I always do that unless the file has Clean ME in its name, it never hurts doing it twice.
        A working TV? How boring!
        • Marco_compucell
          • Feb 2012
          • 67
          • South Africa
          #64
          Hello can someone pleas help me to remove Bios password
          Thank You
            • 21031
            Try this one .
            • Marco_compucell
              • Feb 2012
              • 67
              • South Africa
              #66
              Thank you SMDFlea will try it on Monday
              • Marco_compucell
                • Feb 2012
                • 67
                • South Africa
                #67
                Thank You SMDflea it works
                • servis_null
                  • Oct 2014
                  • 82
                  • Croatia
                  #68
                  Hi to all,
                  I need pass remove from bios dump.
                  elitebook 840 g3 mb: 6050A2822301-MB-A01
                  thnx
                    • 21031
                    Originally posted by servis_null
                    Hi to all,
                    thnx
                    Try this one.
                    • Ahnenerbe
                      • Apr 2018
                      • Ukraine
                      #70
                      SMDFlea can You also help me with this disaster as much as possible.
                      - Thnx!
                      m.b.: 6050A2892401-A01
                      • servis_null
                        • Oct 2014
                        • 82
                        • Croatia
                        #71
                        Originally posted by SMDFlea
                        Try this one.
                        Thnx SMDFlea, works great. Thnx again
                          • 21031
                          - Thnx!
                          Try this one
                          • salawayon
                            • Nov 2012
                            • 572
                            • philippines
                            #73
                            Re: HP 840 G3 bios needed
                            got another unit with same issue... motherboard model is the same with the first one...
                            i attached my backup... thanks...
                            • dimkka
                              • May 2013
                              • 16
                              • moldova
                              #74
                              • dimkka
                                • May 2013
                                • 16
                                • moldova
                                #75
                                Thank You
                                • sourcebf
                                  • Jul 2016
                                  • 431
                                  • N/A
                                  #76
                                  thank you
                                  here you go
                                  • salawayon
                                    • Nov 2012
                                    • 572
                                    • philippines
                                    #77
                                    anyone could remove the bios password?
                                    thanks...
                                    • dimkka
                                      • May 2013
                                      • 16
                                      • moldova
                                      #78
                                      Originally posted by sourcebf
                                      here you go
                                      i use the file upstair, all not working. (no display)
                                        • 21031
                                        Try this one .
                                        • sourcebf
                                          • Jul 2016
                                          • 431
                                          • N/A
                                          #80
                                          I used your original file, and remove the password from it
                                          after programming the new dump wait laptop takes few seconds to post
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
