bios dump elitebook 840 g3
Re: HP EliteBook 850 G3 corrupted extracted image
hello,
please help me imstuck with remove admin bios password
i maked dump with CH341A from hp elitebook 850 g3 with board 6050A2892401-mb-a01 and chip 25Q128FVPQ i uploaded here the file please help im stuck
because i have erased the chip and i tried diferent bios bin files
fan full load black screen capslock and numlock flashing
best regardLast edited by SMDFlea; 04-02-2023, 12:22 PM.Comment
try..hello,
best regardLast edited by SMDFlea; 04-02-2023, 12:22 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
hello,
thank you very much for help but didn't worked just flashed bios chip and placed on but laptop doesn't come on led flashing no fan. i used AsProgrammer with ch341a and by verification after flash have a error i add this in txt you can see in attachment
best regardsLast edited by SMDFlea; 04-02-2023, 12:22 PM.Comment
Try NeoProgrammer - https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
If you still have verification issues the chip is bad .You have desoldered the bios ?Comment
hello, i try it now, yes it is desoldered and i try with wires too because of not sure with the ground... the Neoprogrammer have there buttons UNPROTECT what to do with? there are SREG and edit sreg still doesn't work blinking white orange light i think im wrong with the bios because i have first time readed with CH341A Programmer v1.4Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: bios dump elitebook 840 g3
Hello friends ,, and I have the same problem .. There is a password on the BIOS. I tried the BIOS that friends put up here previously, but none of it worked
Motherboard number 6050a2728501-mb-a01
I have attached the original BIOS file
https://drive.google.com/file/d/11V2...ew?usp=sharingComment
https://www.badcaps.net/forum/showthread.php?t=79956Hello friends ,, and I have the same problem .. There is a password on the BIOS. I tried the BIOS that friends put up here previously, but none of it worked
https://drive.google.com/file/d/11V2...ew?usp=sharingDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello. I buy an Elitebook 840 G3, 650a2892401-mb-a01 and the result is that I can always imagine a black pants and a fast fan ....
any solution? .. by sight I have some MX25L12805D chips, I have made a copy of both, I have tried several and I can't get it to work ... can someone help me? ThanksComment
post the bios backup.Hello. I buy an Elitebook 840 G3, 650a2892401-mb-a01 and the result is that I can always imagine a black pants and a fast fan ....
any solution? .. by sight I have some MX25L12805D chips, I have made a copy of both, I have tried several and I can't get it to work ... can someone help me? ThanksDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
enter the DMI information.
https://www.youtube.com/watch?v=9T57ktw8n3YDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
has this, thank you very much.
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
