bios dump elitebook 840 g3
  • peste
    • 13312
    • ROMANIA
    #641
    Re: bios dump elitebook 840 g3
    Originally posted by raizenn27
    i have hp bios with password can you unlock..,thanks
    use RCUnlocker and unlock it yourself.
    • DanielDacko
      • Mar 2015
      • 326
      • Macedonia
      #642
      try...
      I don't provide help for people using CH341A and a clip.
      • titmos
        • Apr 2015
        • nigeria
        #643
        Hello, Please I really this issue with computrace/absolute persistence set to active. Attached here is the bios dump
        840 g3
        6050a2892401 A01
        • Psich
          • Jun 2022
          • 10
          HP Elitebook 840 G3 BIOS dump
          Hello Guys I need Main BIOS dump for HP Elitebook 840 G3
          My original dump is brickt, i have no original BIOS dump.
          Pleas Help me.
          Mainboard:
          6050A2892401-MB-A01
          ProID: L3C65AV
          SN# 5CG6520S9B
          Thanks!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12234
            #645
            Re: HP Elitebook 840 G3 BIOS dump
            Post your corrupt bios here.
            • Psich
              • Jun 2022
              • 10
              I dont have, the bios chip is broken(blown)
                • 21568
                Please read the bios posting rules.You must post under a related thread if there is one.
                Use the forum search,you can often find a related post that way,then you don`t have to start a new thread.
                • Psich
                  • Jun 2022
                  • 10
                  OK sorry
                  • Psich
                    • Jun 2022
                    • 10
                    can someone help me?
                      • 21568
                      Search through this thread for a bios with clean ME firmware such as post #442. If a bios is titled outimage,ME Clean,clean ME they most likely have cleaned firmware.Use HP bios config utility to add missing DMI info
                      • Psich
                        • Jun 2022
                        • 10
                        Unfortunately I don't know much about it...
                          • 21568
                          You said your chip is broken,broken how,is it burned.Did you buy a new chip,do you have an SPI bios programmer
                          • Psich
                            • Jun 2022
                            • 10
                            Yes, I wanted to remove the bios password and made the chip too hot. I already have a new chip and a SPI programmer
                              • 21568
                              try the bios at post #442
                              • Psich
                                • Jun 2022
                                • 10
                                Ok I'll try
                                • SHONE984
                                  • Mar 2022
                                  • 33
                                  • stockholm
                                  #656
                                  pleasse can somone clear the password .
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12234
                                    #657
                                    https://www.badcaps.net/forum/showth...ght=rcunlocker
                                    • DanielDacko
                                      • Mar 2015
                                      • 326
                                      • Macedonia
                                      #658
                                      here you go.
                                      • DanielDacko
                                        • Mar 2015
                                        • 326
                                        • Macedonia
                                        #659
                                        Can you explain the difference between my unlocked file and the file unlocked by RCUnlocker? Not trolling, just interested, since I am not very good with hex editors. Seems that RCUnlocker leaves some data behind, while my software doesn't.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12234
                                          #660
                                          There is a difference, but this bios file only needs to intervene in the "U.s.e.r.C.r.e.d" area.
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
