Dell Alienware m17x r4 qbr00 la-8341p bios dump
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    Hello please I need the bios dump of this motherboard if somebody can help me
    Dell Alienware m17x r4 QBR00 LA-8341P REV : 1.0
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    Re: qbr00 la-8341p bios dump
    Any help
    • sushi1
      • Aug 2017
      • 32
      • Egypt
      So the laptop has a corrupted bios, i want the A15 BIOS file so i can flash it directly on the chip, as well as the EC bin File, i found these files here however the EC file was 1024KB, i think it should be 128KB to fit the chip if im not mistaken. And the BIOS version is not what i needed.
      • peste
        • 13581
        • ROMANIA
        post S/N, full name and model, motherboard model, etc.
        post the contents of the bios chip even if it is corrupted..(main+EC)
        • sushi1
          • Aug 2017
          • 32
          • Egypt
          Dell Alienware M17xR4
          Motherboard Model : LA-8341P
          BIOS Chip model: Winbond w25q64fv
          EC Chip : Winbond 25x10bvnig
          CPU: i7-3630QM - Ivy Bridge
          Also it has the 3d display 120hz, so it can't ever run on the integrated GPU (not sure how that info is relevant)
          Backup (corrupted) contents attached, what makes me think they're corrupted, or at least one of them is, the power cord unplugged while installing BIOS and giving 7 beeps on startup ever since.
          • peste
            • 13581
            • ROMANIA
            Also it has the 3d display 120hz, so it can't ever run on the integrated CPU (not sure how that info is relevant)
            write only the 8MB chip..the other chip remains the same...
            • sushi1
              • Aug 2017
              • 32
              • Egypt
              Thanks for the prompt response.. quick question before installing it I'm just making sure, did you check the other one (EC file) ? does it look normal?
              • sushi1
                • Aug 2017
                • 32
                • Egypt
                Update, I installed the one you sent me and kept the other one as is.. then tried to switch on the laptop, now it does even beep or give any lights.
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • jhanra
                  by jhanra
                  11-02-2024, 04:19 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
