hp elitebook 840 g4 need password unlock
    • 22009
    Originally posted by kafarda
    My Bios is Password protected, Help me clear the password please.
    HP EliteBook 840 G4
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • kafarda
      • Jul 2019
      • 21
      • Nigeria
      #242
      HP EliteBook 840 G4
      now the system is showing "Problem with EndPoint security"
      Model: HP EliteBook 840 G4
      Product ID: Z2V44ET#ABU
      SN: 5CG7421R8E
      Board ID: 6050A2939701
        • 22009
        SN: 5CG7421R8E
        Try these fixes
        https://www.badcaps.net/forum/troubl...55#post3310855
        https://www.badcaps.net/forum/troubl...security-error
        • bbanana
          Father Land
          • Oct 2021
          • 164
          • Vietnam
          #244
          SN: 5CG7421R8E
          pls attach your 32mb bios, delete nvram in EC sometimes has this issue with newer bios version.
          • kafarda
            • Jul 2019
            • 21
            • Nigeria
            #245
            Here is the Locked Bios, its 16MB
            • bbanana
              Father Land
              • Oct 2021
              • 164
              • Vietnam
              #246
              this board have 2 bios chip, 16MB and 32MB main bios. i need this 32mb bios to try to help you
              • kafarda
                • Jul 2019
                • 21
                • Nigeria
                #247
                These are the Pictures of my MB, If I backed up the BIOS it turns out to be 16MB not 32MB
                  SMDFlea commented
                  Editing a comment
                  look on the other side of the board for the 32MB chip.
              • kafarda
                • Jul 2019
                • 21
                • Nigeria
                #248
                The other side doesn't contain a any BIOS chip
                • rex98
                  • Feb 2023
                  • 1293
                  • Mandaue CEBU, Philippines
                  #249
                  here
                  • kafarda
                    • Jul 2019
                    • 21
                    • Nigeria
                    #250
                    Originally posted by rex98
                    here
                    It worked, the error and password disappeared, thank you and the BadCaps Team.
                    • akande
                      • Dec 2017
                      • 278
                      • Nigeria
                      #251
                      HP 840 G4 ADMIN LOCK , I need code remove please
                      proid: X3V06AV
                      SN: 5CG8035056​
                      • rex98
                        • Feb 2023
                        • 1293
                        #252
                        proid: X3V06AV
                        SN: 5CG8035056​
                        here
                        • akande
                          • Dec 2017
                          • 278
                          • Nigeria
                          #253
                          here
                          after progrmming chip,
                          it keep showig this: Entering third party rom management.
                          i tried factory rest , change ssd still no result
                          • rex98
                            • Feb 2023
                            • 1293
                            #254
                            here this should work.
                            first boot press f10 apply factory defaults and exit.
                            use BCU. you can permanently disable Absolute lock in BCU.
                            here's your dmi:
                            Serial Number: 5CG8035065
                            Product #/SKU: X3V06AV
                            CT Number: PGDUF00WBAD183
                            Description: HP EliteBook 840 G4
                            BuildID: 16WWCSCT601#SABU#DABU
                            Feature Byte: 3X476J6S6b757H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqgd.2G
                            MAC Address : 80:CE:62:A1:AD:54​
                            • akande
                              • Dec 2017
                              • 278
                              • Nigeria
                              #255
                              here's your dmi:
                              How to diable permanet absolute lock in BCU, Because Admin code keep appearing after follow the procedure
                              thanks
                              • sassan
                                • Apr 2014
                                • 82
                                • France
                                #256
                                hello,
                                i have elitebook 840r g4 stuck at finishing bios update loop,
                                tried clean me ,same problem,
                                SN: 5CG91017QS
                                any help please..
                                • peste
                                  peste commented
                                  Editing a comment
                                  post merged..
                              • qasim3344
                                M Qasim Raza
                                • Dec 2022
                                • 9
                                • United Arab Emirates
                                #257
                                HP 840R G4 PLZ UNLOCK AND CLEAN ME
                                SN NO#5CG9219J9L​
                                • qasim3344
                                  M Qasim Raza
                                  • Dec 2022
                                  • 9
                                  #258
                                  here's your dmi:
                                  FILE NOT DOWNLOAD
                                  • p2n
                                    • Aug 2025
                                    • 3
                                    • NL
                                    #259
                                    Please help me remove the BIOS password. Thank you very much in advance!
                                    Product ID: 4SB16EC#ACB
                                    SN: 5CG8212VKT
                                    • p2n
                                      • Aug 2025
                                      • 3
                                      • NL
                                      #260
                                      SN: 5CG8212VKT
                                      I apologize, but can anyone help me remove the BIOS password? Or perhaps you could provide instructions on how I can obtain the necessary BIOS from the existing one myself?
                                      • moshu
                                        HP EliteBook 755 G4 bios password locked
                                        by moshu
                                        Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                        I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                        Can you please help to remove the password?
                                        after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                        HP EliteBook 755 G4
                                        ProdID: W5Q98AV
                                        SN: 5CG7524BY4...
                                        02-01-2025, 06:59 AM
                                      • marc_ytos
                                        request unlock HP EliteBook 640 G11 password bios
                                        by marc_ytos
                                        Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                        01-11-2025, 06:20 PM
                                      • Modify_inc
                                        Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                                        by Modify_inc
                                        I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                                        11-02-2021, 11:14 AM
                                      • ibo
                                        Elitebook 655 G10 Bios Password Unlock
                                        by ibo
                                        Can somebody unlock this bios?
                                        Serial 5cd329740h...
                                        10-18-2024, 10:00 AM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
