hp elitebook 840 g4 need password unlock
  • darkpower
    • Oct 2019
    • 13
    • France
    #81
    Re: hp elitebook 840 g4 need password unlock
    I tried to put a testing clamp on the bios socket, but did not work. The bios uses a Winbond 25Q128JVPQ and it has no leads. How did you do guys to reprogram it? Any help would be appreciated.
    • e900
      • 26
      Originally posted by Nico Latour
      send me pm or contact me on telegram @hansworst, then i show you pics
      Hi
      Im in the same position, would you be kind to share pics on the forum?
      I have a soic 8 and the pins are short or above the contact points for the board.
      My soldering skills are not great.
      • ramzyharb
        • Feb 2017
        • 11
        • omega
        #83
        Hp 840 g4 bios remove password
        Hi guys help me need bios reset thats my dump
        • peste
          • 13915
          • ROMANIA
          #84
          Re: Hp 840 g4 bios remove password
          try...
          • ramzyharb
            • Feb 2017
            • 11
            • omega
            #85
            Still need password
            • peste
              • 13915
              • ROMANIA
              #86
              try...
              • ramzyharb
                • Feb 2017
                • 11
                • omega
                #87
                Still locked
                • peste
                  • 13915
                  • ROMANIA
                  #88
                  your bios is corrupt, try it ...
                  • darkpower
                    • Oct 2019
                    • 13
                    • France
                    #89
                    Originally posted by zenek_19
                    mcplslg123
                    Thank you works perfect
                    Hello @zenek_19,
                    Did you remove the eeprom or is there any way to reprogram or without removing it? Please help me.
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #90
                      Originally posted by darkpower
                      Hello @zenek_19,
                      Best way is to remove the chip from the board, you can try to solder wires to the chip also, but this not always work with HP laptops. What is the problem, de soldering the chip from the board is not a hard job, even without the hot air station?
                      Become a Badcaps supporter
                      Thanks to all supporters.​
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #91
                        It has a WSON8 packaged EEPROM. Can't unsolder it without hot air.
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #92
                          If it's a WSON8 package bios chip - yes, the only option is hot air.
                          • darkpower
                            • Oct 2019
                            • 13
                            • France
                            #93
                            Thank you guys for your help.
                            Regards
                            • darkpower
                              • Oct 2019
                              • 13
                              • France
                              #94
                              Hello Vesko356,
                              I'm actually afraid of breaking something on the mother board or something like that, do you have some advices/tutorials/other instructions to give me sothat I do it as safely as possible?
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #95
                                Hello Vesko356,
                                About desoldering the chip with the hot air station? The job is not hard if you have some experience, if not just use some faulty motherboard to practice, it's a straightforward job, nothing special, just use good flux like AMTECH 213 or 559, use small or medium nozzle and not too much air (you can blow some small surrounding component if you use too much air), I would say half air ahd about 360 C will do the job perfectly.
                                P.S. Forgot to say - if you have surrounding plastic components, take care to cover it all with the kapton tape, or you will melt something very easily!
                                And last but not least pay attention about the chip position.
                                P.S.2 You can watch this youtube video for education, and how to do it.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #96
                                  I don't agree that you can blow away surrounding components with max air. The surface tension hold those components in place. You would have to physically move those components to make them fly away.
                                  The only probleem is plastics melting. But on elitebooks, it is usually not a problem. On ProBooks, it is mostly a big problem. On this model, only the thin plasti under SSD will be deformed. Wouldn't call it an issue.
                                  Just remove bios battery before soldering and you should be fine. It might take a while for the bios chip to start moving so please be gentle with the tweezers. Do not use force with the tweezers, it is pointless and harmful.
                                  • PawelPL
                                    • Feb 2020
                                    Hi, can i try any of the files uploaded above for my 840 G4 and it will work or it has to be specific for individual machine? Thanks
                                    • peste
                                      • 13915
                                      • ROMANIA
                                      #98
                                      put the bios backup here
                                      • PawelPL
                                        • Feb 2020
                                        How do i do it? Thank you.
                                        btw - my bios is locked, but can boot from usb...
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #100
                                          It's specific - serials etc., so first take a good verified dump of your machine and upload the file here for unlock. After that you can write unlocked file back to the bios chip.
                                          • moshu
                                            HP EliteBook 755 G4 bios password locked
                                            by moshu
                                            Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                            I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                            Can you please help to remove the password?
                                            after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                            HP EliteBook 755 G4
                                            ProdID: W5Q98AV
                                            SN: 5CG7524BY4...
                                            02-01-2025, 06:59 AM
                                          • marc_ytos
                                            request unlock HP EliteBook 640 G11 password bios
                                            by marc_ytos
                                            Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                            01-11-2025, 06:20 PM
                                          • Modify_inc
                                            Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                                            by Modify_inc
                                            I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                                            11-02-2021, 11:14 AM
                                          • ibo
                                            Elitebook 655 G10 Bios Password Unlock
                                            by ibo
                                            Can somebody unlock this bios?
                                            Serial 5cd329740h...
                                            10-18-2024, 10:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
