hp elitebook 840 g4 need password unlock
  • darkpower
    replied
    Re: hp elitebook 840 g4 need password unlock
    Soldering back the chip can be hard sometimes. In fact got some trouble at the beginning to solder it correctly as there were too many tin on the central attachment of the chip on the motherboard. So first remove as much tin as you can from the center, and add more tin to the leads place, then with hot air, solder it back and it should work.
    Regards
  • lapfix
    replied
    Originally posted by jaggi_32
    Doesnt work. Caps lock blinking forever.
    Re solder the chip carefully , take care if there's resistance near chip
    legs
  • jaggi_32
    replied
  • black0hackers
    replied
    Doesnt work. Blank screen and 5 blinks on power button and caps lock. Checked the soldering, it is soldered well.
    here you are!
  • jaggi_32
    replied
  • peste
    replied
    Request password unlock for HP Elitebook 840 G4. Attached the BIOS extract. Many thanks!
    try..
  • jaggi_32
    replied
  • black0hackers
    replied
    Re: Hp 840 g4 bios remove password
    Originally posted by peste
    post the original bios and EC bios
    i dont have it, i need it
  • peste
    replied
    Originally posted by black0hackers
    i need Main and EC bios File 840 g4
  • black0hackers
    replied
  • darkpower
    replied
    Originally posted by gualancho
    good morning is it possible to desolder the chip with soldering iron?
    No absolutely not, the chip has no leads, so you absolutely need hot air... You can buy cheap one from china directly, I got one for 22€ delivered to my home.
    Good luck
  • peste
    replied
    search for videos on the net for this issue.
  • gualancho
    replied
  • darkpower
    replied
    Steps to flash the bios of elitebook g4 840:
    1- Open the laptop
    2- Remove the battery then the SSD which is very close to the bios chip
    3- protect the surroundings of the bios with aluminium foil or kaptopn tape if you have
    4- remove the wson8 packaged bios chip with a heat gun after putting some flux (if you don't have hot air soldering station you cannot do it!!!)
    5- connect it to ch341a programmer using twizzers or by soldering it
    6- make 2-3 copies of the locked bios and verify each time that the buffer & content of the chip are exactly the same (very important)
    7- post the bios on the forum
    8- download the unlocked bios
    9- Erase the eeprom and write the unlocked bios
    10- Solder the bios back on the laptop after applying flux, put more tin on the contacts and remove tin from the central one (this might prevent the pins of the chip to be well connected)
    11- put back the laptop battery (5 fast blink and 2 long blinks that I got before means that the chip is not well soldered, the laptop did not find the bios)
    12- start the laptop, it should be saying invalid time...
    13- enjoy!
  • darkpower
    replied
    Originally posted by imranromi
    Try this and reply.
    Hello, finally it worked well thank you very much
    Regards
  • darkpower
    replied
    Hello, yes I posted the original bios from my computer not the one I downloaded from the site...
    Regards
  • peste
    replied
    Originally posted by darkpower
    Hello thanks for prompt bios sending...
    Same problem, red flashing 5 times (fast) then green bkinks one time (slow blink). Could be some other issue? is it possible that I installed wrongly the chip (I'm sure I installed in the good position as it was before)?
    post the original bios not the one you tried on the site.
  • darkpower
    replied
  • peste
    replied
    I have a password locked (limited lock) cannot update bios... I tried one of the bios submitted in this forum but did not work (motherboard blinking once I put in the bios), here is my password protected bios, can you please unlock it and give me one that works?
    Thanks guys
    try..
  • darkpower
    replied
    Thanks guys
  • moshu
    HP EliteBook 755 G4 bios password locked
    by moshu
    Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
    I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
    Can you please help to remove the password?
    after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
    HP EliteBook 755 G4
    ProdID: W5Q98AV
    SN: 5CG7524BY4...
    02-01-2025, 06:59 AM
  • Modify_inc
    Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
    by Modify_inc
    I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
    11-02-2021, 11:14 AM
  • marc_ytos
    request unlock HP EliteBook 640 G11 password bios
    by marc_ytos
    Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
    01-11-2025, 06:20 PM
  • ibo
    Elitebook 655 G10 Bios Password Unlock
    by ibo
    Can somebody unlock this bios?
    Serial 5cd329740h...
    10-18-2024, 10:00 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
