Re: hp elitebook 840 g4 need password unlock
HP EliteBook 840 G4
HP Sure Start enabled
Can somebody unlock please?
Thanks!
the file i posted before was raw and the password had not been removedLeave a comment:
Do I have to make dump of the EC bios as well if the laptop is "Protected by HP Sure Start".
Or is a dump and password removal of the main bios enough?Leave a comment:
Re: 840 G4 6050A2854301-MB-AO1 bios lock
Hello members, I have the same problem as all of you. My BIOS is locked. I need to unlock it. I have backup file, from my BIOS IC, which is MX25L12873F.
BIOS backup file you can find here. Can unlock that file and write the steps for additional tasks to do that everything work well. As I understand correctly, you have to do more that overwrite BIOS file.
https://www.youtube.com/watch?v=9T57ktw8n3YLast edited by SMDFlea; 04-10-2023, 12:39 PM.Leave a comment:
BIOS backup file you can find here. Can unlock that file and write the steps for additional tasks to do that everything work well. As I understand correctly, you have to do more that overwrite BIOS file.Last edited by SMDFlea; 04-10-2023, 12:39 PM.Leave a comment:
HP Elitebook 840 G4
Hello all, need help fixing this bios. From HP site only bios region i got.
Someone already flash this bios but failed and won't turn on, before he flash the problem only no display. Here's the backup
Thank you very muchLast edited by SMDFlea; 04-10-2023, 12:39 PM.Leave a comment:
Unfortunately, each bios in those laptops is unique, so no, you cannot expedite the process. The only way of accelerating process is to have the password, which I guess is impossible, but worth asking... Hopefull the one that sold you the laptops have the password, or can ask the password from the enterprises he gets them from.
A way to accelerate things though, is to remove the password yourself from the files, which is possible, by removing some binary data and replacing it by 0xFF or 0x00 at certain places.
Process is:
- Remove the bios chip
- Read it and make sure your read it well
- remove the password
- write the new bios in it
- resolder it back
For hundred of laptops it will be painful, but after getting used to the process, you will be able to treat one laptop in 30 minutes.
Good luckLeave a comment:
try..Last edited by SMDFlea; 04-10-2023, 12:39 PM.Leave a comment:
i don't have backup. I was buy motherboard without CHIP. I buy chip and all voltage and resistant looks ok so probbly it was bios issue and someone can't fix this so sold motherboard...Leave a comment:
by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
Can you please help to remove the password?
after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
HP EliteBook 755 G4
ProdID: W5Q98AV
SN: 5CG7524BY4...-
Channel: BIOS Requests ONLY!
by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
by marc_ytosGreetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
- Loading...
