hp elitebook 840 g4 need password unlock
    commented on 's reply
    "or alternatively use a WSON8 pogo adapter (unreliable YMMV)" .The most reliable way is to desolder the chip using a hot air station.
  • peste
    replied
    Originally posted by mp2172
    How do I post the 16MB bios?
    down right.....QUOTE, bottom left..Upload Attachments..etc...
  • mp2172
    replied
    Originally posted by SMDFlea
    You will need an SPI bios programmer to make a backup of the chip.The chip is in a WSON8 package,so you will need to desolder it first ,then put it into a WSON8 adapter or alternatively use a WSON8 pogo adapter (unreliable YMMV) .Then read the chip a few times,check to make sure you`ve made a good backup, then post it here inside a zip or rar attachment.
    1. How to dump and flash
    1.1. BIOS
    https://www.badcaps.net/forum/troubl...21#post1622421
    Thank you. So basically, RCUnlocker or any other tool can't bypass/reset the Administrator BIOS password without removing the chip?
    replied
    You will need an SPI bios programmer to make a backup of the chip.The chip is in a WSON8 package,so you will need to desolder it first ,then put it into a WSON8 adapter or alternatively use a WSON8 pogo adapter (unreliable YMMV) .Then read the chip a few times,check to make sure you`ve made a good backup, then post it here inside a zip or rar attachment and also post the laptop serial number.
    1.1. BIOS
  • mp2172
    replied
  • peste
    replied
    Hi, could someone please help me with HP EliteBook 840 G4, sn - 5CG7105G3M
    read..https://www.badcaps.net/forum/troubl...before-posting
    post the 16 MB bios
  • mp2172
    replied
  • mp2172
    replied
    Hi, is RCUnlocker used when you don't have the BIOS Administrator password? If so, how do we know which .bin file to use?
  • Vesko356
    Thread merged.
    Read the rules before posting please! You must post under a related thread if it exists!
    Additionally unlocking method for this laptop model is available at BIOS guides, methods, resources and tools​ thread!
  • fixxz
    replied
    yes it worked thank you
  • leo037_2023
    replied
    Originally posted by fixxz
    HP EliteBook 850 G4,6050A2854301-MB-A01
    try and tell ME , use rcunlocker.
  • qayyum786
    replied
    Use ​RCUnlocker from post #1
    Click me to download
  • fixxz
    replied
  • yinlaino
    thanks it worked thanks
    replied
    Originally posted by yinlaino
    Hello, can you help me by removing the bios password, thank you
    Read some of the previous posts.Have you tried RCUnlocker ? .You must post the laptop serial number .
    https://www.badcaps.net/forum/troubl...before-posting .
    You MUST:Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
  • yinlaino
    replied
  • peste
    replied
    Re: hp elitebook 840 g4 need password unlock
    Originally posted by Rajserp
    Is it possible to read and flash back the bios in circuit on the 840 G4 using the CH341A? I can see it is possible to solder small wires to the exposed pads around the bios chip. I have the small wire and iron tips, but don't have a hot air station.
    yes... you can stick wires between the programmer and the bios chip..
  • Rajserp
    replied
  • aldopc
    replied
    Originally posted by aldopc
    Hello friends, can someone help me with this bios that has computrace activated.
    solved
  • aldopc
    replied
  • moshu
    HP EliteBook 755 G4 bios password locked
    by moshu
    Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
    I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
    Can you please help to remove the password?
    after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
    HP EliteBook 755 G4
    ProdID: W5Q98AV
    SN: 5CG7524BY4...
    02-01-2025, 06:59 AM
  • marc_ytos
    request unlock HP EliteBook 640 G11 password bios
    by marc_ytos
    Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
    01-11-2025, 06:20 PM
  • Modify_inc
    Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
    by Modify_inc
    I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
    11-02-2021, 11:14 AM
  • ibo
    Elitebook 655 G10 Bios Password Unlock
    by ibo
    Can somebody unlock this bios?
    Serial 5cd329740h...
    10-18-2024, 10:00 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
