need bios for dell E7440
Re: need bios for dell E7440
try.. please confirm
thanks and goodluckAttached FilesComment
i havee dell latitude e745 service tag; bqpd562-1f66 , cant find any passworld for this i searched on bios-pw and doesnt workComment
try this bios
Main & EC for ZBU10 LA-A961PAttached FilesComment
do you have spi programmer?
file from sourcebf can flashing only using spi programmer.Comment
Re: Vaua0 la-9591p dell latitude e7440 bios needed
Yes thank you Bachir2004, good job - bios is OK. Both files (Main and EC) are confirmed working.
I've cleaned ME Firmware from the main 8MB dump, below is the cleaned file ready for programming.Attached FilesLast edited by Vesko356; 09-14-2020, 01:20 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: I need a Dell Latitude E7440 Bios file
tryAttached FilesComment
https://www.badcaps.net/forum/showthread.php?t=63782
https://www.badcaps.net/forum/showpo...39&postcount=6
No.----------------------------------------------------------------------------------------------------------------------------------------------------------
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
