BIOS for Asus X450VP rev2.1 with ATI graphics
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: BIOS for Asus X450VP rev2.1 with ATI graphics
    Does anybody know why ME_AC_PRESENT does not go high?
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      I think could we ignore the signal ME_AC_PRESENT. Just go to check signal 1.5_ON, might be that signal was present after you pressing power button. If yes, then check on Low side mosfet on block 1.5 (pin 4 PQ8301/pin 15 PU8300). Because signal En for controller 1.5VO coming not from SUSC signal. Just guessing, maybe this point was clue the problem.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        signal 1.5_ON is not present.
        SIO generates RSMRST and 3v_SUS_ON and other signals after pressing the power button.
        should be they generated after plugging adapter in before pressing the power button?
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          What I thought if there's signal premature, seem it not happen. Signal 1.5_ON generated after pressing power button.
          Asus X450VP seem as revision of X450CC, as far I know it board almost had problem only with regulator 3V and 5V.
          does +12VSUS have correct voltage?
          does 3VSUS_PWRGD signal present?
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            both 12VSUS and 3VSUS_PWRGD are present. may be, this board can not be fixed.
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              #26
              I do not know why PM_SUSC is not generated by PCH.
              In this laptop, BIOS chip is connected to SIO. SIO reads BIOS, but PCH does not.
              Does PCH read BIOS before generating PM_SUSC?
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                #27
                does anyone know at which stage PCH reads Bios chip for the first time during startup?
                is it S4 , S3 or S0?
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  #28
                  I need Bios for Asus D452V Laptop.
                  mainboard model: X450VP REV. 2.1
                  note1: my original bios in post 1 and 2 are probably damaged, because I tested them and got no result.
                  note2: I already got bios of mainboard x450cc rev2.1. I tested it. It was good considering SIO but PCH does not turn on. I downloaded it from this thread: https://www.badcaps.net/forum/showpo...13&postcount=2
                  • cacla
                    • Apr 2015
                    • 442
                    #29
                    try this one and pls sent msg if is ok or not
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      #30
                      thank you, I will report back tomorrow.
                      • caspian
                        • Oct 2015
                        • 1589
                        • Laptop
                        #31
                        I carefully looked at the markings on the laptop. I realized that laptop model is Asus X452CP. So I appreciate if someone uploads bios dump for this laptop:
                        Laptop model: Asus X452CP
                        Mainboard model: X450VP REV. 2.1
                        the original dump is in the first post that does not work.
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          #32
                          this is your bios
                          Im Back... sort of...
                          • caspian
                            • Oct 2015
                            • 1589
                            • Laptop
                            #33
                            thank you. I will program it and report back tomorrow.
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              #34
                              it did not work because the SIO and the PCH seem faulty.
                              • caspian
                                • Oct 2015
                                • 1589
                                • Laptop
                                #35
                                Now I need boardview for Mainboard model: Asus X450VP REV. 2.1
                                thanks If someone uploads it.
                                note: I already got boardview for X450CC, but it is a bit different.
                                • cacla
                                  • Apr 2015
                                  • 442
                                  #36
                                  Pls sent me picture from sticker with sn on laptop
                                  • caspian
                                    • Oct 2015
                                    • 1589
                                    • Laptop
                                    #37
                                    The mainboard was not fixed. I'm gonna replace the mainboard by a new one.
                                    • aris_prast1
                                      • Jan 2014
                                      • 70
                                      • Indonesia
                                      #38
                                      Its Solved?
                                      i have the same case
                                      • caspian
                                        • Oct 2015
                                        • 1589
                                        • Laptop
                                        #39
                                        Finally, I figured out the PCH was faulty. The bios dump I uploaded in Post 1 is faulty too. I recommend you use the Bios dump in the following threads:
                                        https://www.badcaps.net/forum/showthread.php?p=755713
                                        https://www.badcaps.net/forum/showthread.php?t=54721
                                        • techkid
                                          • Nov 2016
                                          • 20
                                          • philippines
                                          #40
                                          Originally posted by aris_prast1
                                          Its Solved?
                                          i need asus x450vp boardview any body here can share.... thanks
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                          • DynaxSC
                                            by DynaxSC
                                            06-14-2024, 03:49 PM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Anchar777
                                            ASUS P1412CE need BIOS DUMP
                                            by Anchar777
                                            Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                            06-26-2025, 03:39 AM
