ASUS P1412CE need BIOS DUMP
  • Anchar777
    Anchar
    • Apr 2018
    • Austria
    Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you.
  • lapfix
    • Mar 2020
    • 2732
    • my workshop
    Try this clean me version
    Version 208
    Me version : 15.0.35.1951
    • Anchar777
      Anchar
      • Apr 2018
      • Austria
      Thank you very much, everything works.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • robgerr
        Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
        by robgerr
        Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
        Attach...
        11-17-2023, 09:52 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • DynaxSC
        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
        by DynaxSC
        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
        11-06-2022, 05:22 PM
