Hp 14-AM065TU 6050A2823301-mb-ao1 BIOS NEED URGENT
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp 14-AM065TU 6050A2823301-mb-ao1 BIOS NEED URGENT
    Xeltek superpro 500p is 3.3v. You will need a 1.8v adapter to program it. Just search in google ,you can get it. If you dont have the adapter, i can give you a temporary workaround. Remove the bios chip from mb and put it in the socket of your superpro programmer. Now solder Pin4(GND) of eeprom from motherboard to Pin4 of programmer socket, similarly solder a wire on PIN1 of eeprom on mb to pin1 of programmer socket. Now connect the programmer with your PC and program as usual.
    Attaching the image which may help you.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      I use ch341a cheap programmer and never ever used such adapter, everything works fine
      Im Back... sort of...
      • crowntoy99
        • Oct 2012
        • 264
        • india
        fainal y is don
        i change my programmer thank you
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          amazed to know it works with 1.8v chip. I thinked it works only with3v chips. Will order one today itself though i have Rt809f and xeltek 500p programmer.
          • ganeshcell
            • Jan 2014
            • 80
            • india
            HP 14-ar005tu(6050A2822501-MB-A02 bios needed
            Board id-6050A2822501-MB-A02
            bios needed
              • 20818
              Re: 6050a2822501-mb-a02 bios
              What model number is the laptop,for example 14-Am198nia .Post your bios backup .
              • teqcom
                • Nov 2015
                • 311
                • malasyia
                #27
                here you go
                every bios for every model
                clean me virgin bios
                @alihomee
                your is BID081E1
                hi can u teach me how to make hp bios download from hp webside one thx
                • OVC2001
                  • Sep 2019
                  • 3
                  • México
                  #28
                  HP 14 6050A2823301-MB-A01 Clean
                  • md rubel
                    • Mar 2018
                    • 6
                    • bangladesh
                    #29
                    Re: HP 14-ar005tu(6050A2822501-MB-A02 bios needed
                    bios need plz
                    • bhlindrsah
                      • May 2019
                      • india
                      #30
                      6050a2822501-mn-a01 bios needed
                      • peste
                        • Dec 2016
                        • 12755
                        • ROMANIA
                        #31
                        Post your bios backups here.
                        • haji
                          • Feb 2017
                          • 5
                          • pakistan
                          #32
                          i need bios
                          • peste
                            • Dec 2016
                            • 12755
                            • ROMANIA
                            #33
                            Originally posted by haji
                            i need bios
                            post the full name and model of the laptop and the bios backup
                            • mangga dua
                              • Dec 2023
                              • 6
                              • INDONESIA
                              #34
                              NEED BIOS THIS IS HIS ORIGNAL WITH LOCK
                              thanks
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • survivalbloke
                                Unable to extract bios file from Lenovo bios exectuable
                                by survivalbloke
                                I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                Code:
                                "innoextract 7wcn38ww.exe"
                                it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                The trouble I'm having is that I'm not getting the newly...
                                06-12-2024, 07:55 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
