Hp Pavillion DV-4 bin files need
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    hello there
    I have HP Pavilion DV4- 1435dx
    Problem: no display after 2 or 3 sec. turn off then on Again and so on.
    mobo info: JAL50 LA-4101P
    2009-05-08
    REV:1.0
    check the Volts have 3v and 5v.
    I think it is a Software bios problem...
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    Re: Hp Pavillion DV-4 bin files need
    backup and try one by one......
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      it is a Dump file for this Unit?
      I Appreciate. Thank
      • sourcebf
        • Jul 2016
        • 431
        • N/A
        I Appreciate. Thank
        poste your old bios to confirme which your's....
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          HP_PV_DV4.rar
          here the old back up bin
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            Follow Up this. Thanks
            • lorins_core
              BlackSmith
              • Dec 2012
              • 551
              • Philippines
              Any one have this Dump bin file for this Unit or Can you Clean my old Bin Files Thanks
              • sourcebf
                • Jul 2016
                • 431
                • N/A
                I don't find BID in your old bios but you can try the following, they are from the official hp web site.....one of those will works for you...
                • muzaffar
                  • Jun 2016
                  • 3
                  • india
                  la-4104p bios needed...
                    • 20304
                    All the different bios for the la-4104p are at post #8 ,if you don`t know your BID number you`ll have to try each bios.
                    • compaq
                      • Aug 2017
                      • 4
                      • india
                      HP Pavilion dv4 MB JAL50 LA-4101P BIOS NEDED
                      PROBLEM SWITCHING ON LAPTOP BUT NO DISPLAY
                        • 20304
                        Did you read through this thread ? ,see post #10
                        • JoeBug
                          • Jul 2015
                          • 20
                          • Bulgaria
                          the second one did the job for me.
                          Pavilion dv4 with LA-4101p, no light at power jack led, turning on and off just for seconds, fans spins up and down. intresting, its not turning on at all without (already dead) battery. flashed the first bios - laptop powers on but no picture. flashed the second one and bingo..
                          • abel blondin
                            • Jun 2023
                            • ghana
                            Guys I need hp pavilion dv4 jbl20 la-4111p rev 1.0 bios dump file
                            • peste
                              • Dec 2016
                              • 12246
                              • ROMANIA
                              https://www.badcaps.net/forum/showth...light=la-4111p
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • Cerberuska
                                Mobo MSI B550-A PRO password popup
                                by Cerberuska
                                Hello guys,
                                I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                                BIOS I updated to last one.
                                any suggestions?
                                And same thing for two different 5600G, and yes, MoBo supposed to support it.
                                Thank you...
                                11-10-2024, 01:23 PM
                              • mrsith
                                Dell G3 17 3779 - no display after mobo replacement
                                by mrsith
                                Hi guys,
                                I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                                Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                                04-30-2023, 05:11 AM
                              • Ibod
                                Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                by Ibod
                                HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                Not sure where to go from here ?
                                Is the PSU at fault or is the mobo causing the problem
                                Look forward to any help :-)
                                If I plug the 24...
                                02-08-2023, 11:00 AM
                              • Felipe_Serra_83
                                Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                                by Felipe_Serra_83
                                Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                                So I got this Dell Inspiron to play with.
                                No charger, so I connected to my bench PSU.
                                The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                                ------What it did (and didn't do)------
                                1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                                2) Removed RAM, changed slot. Same...
                                04-04-2024, 12:39 PM
