Asus X550WE Ver.2.0 Bios Dump Please
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Hi friends,
    Does anyone having bios dump for Asus X550WE or F552W ( AMD Platform ).
  • Me.Orouji
    • Dec 2015
    • 117
    • Iran
    Re: Asus X550WE Ver.2.0 Bios Dump Please
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      Originally posted by Me.Orouji
      Thanks for the file. Can you send me the EC ITE8572 Chip for this model.
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        Success. I done flash the bios with Me.Orouji's Bios Dump. Now the laptop working. Thank you for this help.
        • Me.Orouji
          • Dec 2015
          • 117
          • Iran
          Your welcome
          • Cashcobra
            • Jul 2017
            • 26
            • GHANA
            x550we rev 2.0
            any one have this 4m bios plz
            • infomaxcenter
              • May 2016
              • 11
              • Turkey
              Originally posted by Cashcobra
              x550we rev 2.0
              tested 100% work
              • marksik
                • Jun 2019
                • 27
                • Spain
                Originally posted by infomaxcenter
                tested 100% work
                Thank you! It works and it saved my laptop.
                100% working BIOS.
                • Fadda88
                  • May 2017
                  • 12
                  • Italy
                  thanks a lot
                  • iyori20
                    Banned
                    • Nov 2018
                    • 43
                    • maroc
                    thanks y
                    • Abdulrahman
                      • Apr 2019
                      • 9
                      • turkye
                      tested 100% work
                      • Bartoloni
                        • Jul 2018
                        • 140
                        • Italy
                        Working perfectly on X550WE-Rev2, before i tried the 4MB version that was not working (the eeprom ia 64Mb)
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
