What is the purpose of two bios chips on laptop motherboards?
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I ve noticed that on the newer laptop boards there is often two bios chips! For instance, on asus g751 which has gpu and cpu soldered you can find two bios chips, and for instance on asus g750 there is also two, but one on the mainboard and second on the gpu board. For this g750 model there is gpu card, the chip is not soldered to the board...
    So i am wondering what is the purpose of two bios chips? Is second only a backup, or it is responsible for some other things? Strange is that you can also see it on the gpu card...
    Please explain it to me
  • jeremykum
    • Feb 2012
    • 95
    • Malaysia
    Re: What is the purpose of two bios chips on laptop motherboards?
    So far it isn't for backup purpose.
    Generally newer generations uses 2 sets of bios.
    1. Main bios (might includes Intel ME Firmware inside)
    2. EC bios
    You may find sometimes, those bios chip could have same code (hence same capacity) or different codes.
    If I have not mistaken, starting from 4th Gen Intel Core i (Haswell), designers started to integrate the EC bios into the KBC chip, hence more difficult for reprogramming if you are unable to boot up the laptop.
    Some may have a 3rd bios chip. For USB 3.0 purpose.
    As for GPU, not necessarily need a stand alone bios, most design are integrated to the Main Bios.
    Best way is you refer to the schematic for confirmation.
    Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      OK i attached for asus g751 boardview and i zoomed those two bios chips on boardviewer. Can you please tell me what is their function on the board? I believe that U2801 should be main bios...but what is then U9402? please explanation...
      • myth77
        • Feb 2017
        • 380
        • Croatia
        Anyone?
        • subroto
          • Oct 2015
          • 230
          • Bangladesh
          Tell me the chip number of two different EEPROM. I'll tell you the the main BIOS number and EC BIOS number. Usually EC ROM number is like 25x20, 25x40, 25x80 etc. And main one like 25x16, 25x32, 25x64 etc. You may now differentiate between EX and Main BIOS.
          • myth77
            • Feb 2017
            • 380
            • Croatia
            As you can see in the images attached, in the right corner, first chip is winbond W25Q64FVSSIQ and second is winbond W25X40CLSNIG. so the first one would be main and second EC ROM?
            • samanthban
              • Feb 2014
              • 253
              • Sri lanka
              W25Q64FVSSIQ - main
              W25X40CLSNIG.- ec
              sigpic
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                size of chip does not determine role... eprom chip stores data for some external chip to use it, so it could be anything... you can put mp3 song on it if its small enough
                real use for the chip varys from a machine to machine but content can only be disassembled with some decompiler like IDA PRO or some other tool
                even then you have to know arhitecture of chip to disassemble or modify
                this is how whitelist bios are created or unlocked advanced menus for some boards
                so to conclude, eprom can store any data, its like a mini hard drive or mini usb stick
                Im Back... sort of...
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Bloodhoundje
                  HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                  by Bloodhoundje
                  I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                  I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                  After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                  I have desoldered the bios chip (GigaDevice...
                  03-16-2024, 03:12 PM
                • TraJikar Mac
                  [HELP] G712LWS BIOS capsule
                  by TraJikar Mac
                  I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
                  The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
                  You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
                  Also, I uploaded a backup file for the bios that I extracted by using CH341A...
                  06-11-2025, 01:35 PM
