Hi everyone i need a working bios dump file for this model laptop turns on led light steady and fan but there is no display all voltages are present.please anyone share the bios please thanks in advance
Asus zenbook ux305 bios needed
Tags: None
Re: Asus zenbook ux305 bios needed
Anyone has a working bios for this please power light and capslock steady but there is no display -
Thanks for the reply ala borbe i cannot read the bios because it uses different chip and i dont have adapter for this what kind of winbond chip is this attached?Attached Filesif you find these attachements useful please consider making a small donation to the site
Also laptop turns on sometimes but when i shutdown and turn again still no displayComment
Update:i rest the laptop overnight and when i turn on it boots fine but when i shuts down the same issue again turns on with power led light and capslock and blink once the f2 on the keyboard.what is the culprit on this?please helpComment
Thanks for the response ill try to inspect if there is corrosion i cannot flash bios i dont know what type of chip winbond w26q64fviq.the problem is if i rest overnight and turn on on morning it wrks fine but when i shut down turn on with only power led light capslock and f2 blink once.i noticed also cpu is hotComment
Still the same issue if rest overnight turns in and boots fine but when i shut it down turns on with led light and capslock light present but there is no display.anyone can help me pleaseComment
Ill tried update the bios on windows it updates but once restarted same issueComment
Anyone please help still the same issue it turns on and boots fine if laptop rest a day.what could be the problem with this?please adviseComment
At first solved the problem when i rest the laptop for 2days the il try again switch on the it boots fine thw i flashed and update the bios using winflash successfully update problem solved but after a week of using came back the same issue nw laptop turns on but only capslock and f2 and power led light present but no display. I cannot flashed with external programmer because bios chip is different i dont have an adapter for thisComment
i have bought a adapter for this chip WSON8 i successfully read the chip dump i need help to fix this dump can please help me ALA BORBE or TECHMAN to fix this dump file please.problem turn on only capslock and led light steady. attached i upload the original dump . thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Channel: BIOS Requests ONLY!
by ceridwenHi,
I'm having difficulty figuring out how to get a working and properly sized bios for an Asus Zenbook UX425JA. The bios from Asus is 16.25 MB, whereas the XM25QH128A on the motherboard - which I am attempting to program with a CH341A - is 16 MB in size.
SN: L833NBLP0002CXMB
Thanks.
The bios from the website can be found here:...-
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
