Asus zenbook ux305 bios needed
  • String2016
    • Nov 2015
    • 2229
    • philippines
    Hi everyone i need a working bios dump file for this model laptop turns on led light steady and fan but there is no display all voltages are present.please anyone share the bios please thanks in advance
  • String2016
    • Nov 2015
    • 2229
    • philippines
    Re: Asus zenbook ux305 bios needed
    Anyone has a working bios for this please power light and capslock steady but there is no display
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      post bios backup
      Im Back... sort of...
      • String2016
        • Nov 2015
        • 2229
        • philippines
        Thanks for the reply ala borbe i cannot read the bios because it uses different chip and i dont have adapter for this what kind of winbond chip is this attached?
        • String2016
          • Nov 2015
          • 2229
          • philippines
          Also laptop turns on sometimes but when i shutdown and turn again still no display
          • String2016
            • Nov 2015
            • 2229
            • philippines
            Please help on thos please
            • String2016
              • Nov 2015
              • 2229
              • philippines
              Update:i rest the laptop overnight and when i turn on it boots fine but when i shuts down the same issue again turns on with power led light and capslock and blink once the f2 on the keyboard.what is the culprit on this?please help
              • String2016
                • Nov 2015
                • 2229
                • philippines
                Anyone help please what could be the problem with this?
                • sourcebf
                  • Jul 2016
                  • 431
                  • N/A
                  do inspection of all ic's Legs,looking for ic legs corrosion, if you find one perform cleaning....
                  • String2016
                    • Nov 2015
                    • 2229
                    • philippines
                    Thanks for the response ill try to inspect if there is corrosion i cannot flash bios i dont know what type of chip winbond w26q64fviq.the problem is if i rest overnight and turn on on morning it wrks fine but when i shut down turn on with only power led light capslock and f2 blink once.i noticed also cpu is hot
                    • String2016
                      • Nov 2015
                      • 2229
                      • philippines
                      Still the same issue if rest overnight turns in and boots fine but when i shut it down turns on with led light and capslock light present but there is no display.anyone can help me please
                      • String2016
                        • Nov 2015
                        • 2229
                        • philippines
                        Ill tried update the bios on windows it updates but once restarted same issue
                        • String2016
                          • Nov 2015
                          • 2229
                          • philippines
                          Anyone please help still the same issue it turns on and boots fine if laptop rest a day.what could be the problem with this?please advise
                          • String2016
                            • Nov 2015
                            • 2229
                            • philippines
                            any advise on this please still the same issue
                            • String2016
                              • Nov 2015
                              • 2229
                              • philippines
                              Finally i solved the problem on this
                              • mindfx
                                • May 2016
                                • 4
                                • litwa
                                Hi still need this dump , please someone upload
                                • doktortelecom
                                  • Feb 2013
                                  • 6
                                  • Romania
                                  please post the bios original from your laptop, I'll try to compile a working one for you
                                  • doktortelecom
                                    • Feb 2013
                                    • 6
                                    • Romania
                                    how did you solve it ?
                                    • String2016
                                      • Nov 2015
                                      • 2229
                                      • philippines
                                      At first solved the problem when i rest the laptop for 2days the il try again switch on the it boots fine thw i flashed and update the bios using winflash successfully update problem solved but after a week of using came back the same issue nw laptop turns on but only capslock and f2 and power led light present but no display. I cannot flashed with external programmer because bios chip is different i dont have an adapter for this
                                      • String2016
                                        • Nov 2015
                                        • 2229
                                        • philippines
                                        i have bought a adapter for this chip WSON8 i successfully read the chip dump i need help to fix this dump can please help me ALA BORBE or TECHMAN to fix this dump file please.problem turn on only capslock and led light steady. attached i upload the original dump . thanks in advance
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                          ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 06:31 AM
                                        • Tika
                                          ASUS Zenbook Pro 14 Duo OLED ux8402vu BIOS Unlock request
                                          by Tika
                                          Hello, Can someone help me unlocking this asus Zenbook Pro 14 32MB Bios, I try to learn it by searching the whole forum but the guide is for 8MB or 16MB non of them are 32MB and I can't figure it out.
                                          Laptop Brand: Asus
                                          Model code : ux8402vu R2.0
                                          SN: R8N0CV212230358
                                          Bios chip Gigadevice 25R256E
                                          The only problem with this laptop is the UEFI bios locked. I've upload my dump below. Thank you for your help....
                                          03-10-2025, 11:31 AM
                                        • exerion5000
                                          Bios Needed For Asus X515EA Pcb X415EA R2.0
                                          by exerion5000
                                          Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                          Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                          02-17-2025, 01:34 PM
