Lg c500 - bios
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: LG C500 2 sec shuts off
    Anyone please help
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      Anyone please help share EC working dump file please
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        Ill tried back flashed the ec and main to original that i backed up now laptop is dead no lead lights can someone please help me please
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          Anybody can help me please i tried reflash back to original main and ec nw laptop has no power bu ill checked power rail voltage is there present any advise please i need to solved this problem thanks in advance
          • String2016
            • Nov 2015
            • 2242
            • philippines
            I have the same problem with this model i flashed the main laptop turns on but no display but when i flashed the ec bios given here laptop nw is dead no led light but voltage is present could it be ec problem?can somebody please advise or share working ec for this model please
            • tibd
              • Oct 2014
              • 189
              • Sweden
              #26
              I optained the file for LG C500 Pegatron H46Y rev 2.1 from Another website and proven to be working according tp replies. Check if you have the same model as above. The model name is given as file name inside RAR file. If your MB has Another name/ rev then it won't work. How did you flash the EC??
              Would recommend trying another bios chip and flash it with a known good programmer.
              • Romulo
                • Nov 2016
                • 484
                • Philippines
                #27
                Thanks for the response tibd at first i flashed the main with your file laptop turns on automatically fan spinning fast but no display after that i flashed the EC with your file because the same size with my original 64kb i flashed with miniprotl886cs programmer and soldered back when i plugged in laptop nw no power and led lights.it is possible the ec problem?i checkex the motherboard is the same with your file H46y rev 2.1.
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  #28
                  Main bios is winbond W25Q32bv and ec is mx25l512 i checked the voltage on this chip voltage is correct. I dont have another the same chip to replace
                  • tibd
                    • Oct 2014
                    • 189
                    • Sweden
                    #29
                    I had a pair of these 25q32 failing. they seemed to be programmable but never worked, changing them revived the MBs, just a though that it might be so but very hard to say. As i mentioned the dumps are not from som device i own but from a very good website that i never had problem with.
                    • Romulo
                      • Nov 2016
                      • 484
                      • Philippines
                      #30
                      Thanks again for the reply ill try to find w25q32 chip if ever i could not find this what is the replacement for this that working also?can i replace mxic?thanks again
                      • tibd
                        • Oct 2014
                        • 189
                        • Sweden
                        #31
                        try this one instead Before replacing the chip.
                        • Romulo
                          • Nov 2016
                          • 484
                          • Philippines
                          #32
                          Ok thanks again tibd ill try this And feedback soon
                          • Romulo
                            • Nov 2016
                            • 484
                            • Philippines
                            #33
                            Ill tried again flashed the main and ec wiith the late u posted tibd still the same ill find replacement chip fir this thanks
                            • raajkumar
                              • Mar 2015
                              • 354
                              • Srilanka
                              #34
                              Did you solved this problem ?
                              • Romulo
                                • Nov 2016
                                • 484
                                • Philippines
                                #35
                                i already solved this problem by replacing both bios chips
                                • raajkumar
                                  • Mar 2015
                                  • 354
                                  • Srilanka
                                  #36
                                  Ok. So which bios dump you used to flash that new chips ?
                                  • Romulo
                                    • Nov 2016
                                    • 484
                                    • Philippines
                                    #37
                                    after replacing the chip and flashed with rioreno dump it works
                                    • raajkumar
                                      • Mar 2015
                                      • 354
                                      • Srilanka
                                      #38
                                      Ok. I will try that bios dump. I got a laptop it is auto starts and no display. i cannot long press switch off. so i will try flash and inform you.
                                      • Romulo
                                        • Nov 2016
                                        • 484
                                        • Philippines
                                        #39
                                        ok try for flash the main first
                                        • raajkumar
                                          • Mar 2015
                                          • 354
                                          • Srilanka
                                          #40
                                          Which file you use ? is that 2.1mb .bin file or next 4.2mb .pch file ?
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
