cedar_intel-mb 13269-1 bios file
					dell inspiron 15 BIOS NEED 13269-1
	Tags: None
 Re: dell inspiron 15 BIOS NEED
 try this working bios.Attached FilesComment
 Re: Dell inspiron 15 bios
 Dear Friend,
 Here is your dumpComment
 Here is your file its 100% ok I trieddComment
 DELL inspiron15-3000 series Cedar_intel -MB bios
 hi a members
 i need aworking bios of DELL inspiron15-3000 series
 Cedar_intel -MB
 13269-1
 PWB. FX3MC REV:AOO
 i have trying with this but nt working
 https://www.badcaps.net/forum/showth...spiron+15-3000
 and trying with an other dump i have found it . it s working power some seconds and stoping .
 thanksComment
 Re: DELL inspiron15-3000 series
 DELL_Inspiron 15 3542
 REG TYPE P40F001
 REG MODEL P40F
 SERVICE TAG BZ6L912
 EXPRESS SERVICE CODE 26071991030
 Cedar_Intel-MB 13269-1 PWB. FX3MC
 REV A00
 25L6473E-M2I-10G
 BIOS A03
 Try it ........... Attached Files Attached FilesComment
 Dell inspiron 5748 bios dump request
 Hi!
 I have a Dell inspiron 5748 that has a locked bios. I was going to just flash a fresh bios on it, but I can't find an image anywhere ...
 The Dell download lists models 3442,3542,5748, and I know the other two models have bios dumps available in other threads. Maybe they would work...?Comment
 Re: Dell inspiron 5748 bios dump request
 If your mb code is Cedar 13269-1 then most likely it will work from the other 2 models listed. Btw, Bios is different for Intel graphics and Discrete models. So make sure to flash the correct one. Better to clean me region before flashing any dump.Comment
							Channel: BIOS Requests ONLY!
			by sahamipoorhi...
 i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
 i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
 i updated to latest version and try other version but not working!
 service tag: HCQ3JW2
 i need your kind....-
			by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
 cheers
 Dell Inspiron 17 (7786) Laptop
 Service Tag: 5J0NHT2
 Bios: 1.9.0
 MOBO: RO 15 17 WHL 2GB MB / 18706-2
 Attached;
 1. My saved bios using a programmer
 2. Dells Bios updater .exe (v1.16)
 3. Dells Bios recovery file
 4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
 5. Image of ME...-
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...-
 04-23-2025, 04:30 PM
			by GadgetsFixHi everyone,
 I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
 - Model: Dell Inspiron 16 5630
- MainBoard Part Number: 4550SC01C004
- Laptop Serial No: GKH3JX3
- DP/N: 0303KM
- QUAKE N RPL UMA CS MB
- 213251-2
- TMN0H$KB
 Thanks-
- Loading...
