Need bios Asus LA-681P
  • angel-boy
    • 550
    thanks
  • gvm
    • Jul 2016
    Re: Need bios Asus LA-681P
    Would this be an Asus ZAY90 LA-681P board, as fitted to Asus K95VB (and other) laptops?
    If so, bioses are here: https://www.asus.com/Notebooks/K95VB/HelpDesk_Download/ (look under BIOS & tools, select OS "other" and then BIOS). Latest seems to be at http://dlcdnet.asus.com/pub/ASUS/nb/...K95VBAS209.zip .
    Don't know if non-english versions are available but you could try searching other language sections of the Asus site for "K95VB" - Asus don't seem to index on the board number, just the system type.
    Hope this helps.
    • unlockdev
      • 81
      try this bro
      • angel-boy
        • 550
        @unlockdev - power up but no image,
        thanks
        • angel-boy
          • 550
          any other help ?
          • angel-boy
            • 550
            @gvm , the bios is 4mb, i need 8 mb
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              as always, read old non working dump and post here
              Im Back... sort of...
              • angel-boy
                • 550
                see dump
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  asus started pulling shit with bioses, same borad can have multiple different bios
                  anyway, this bios is K95VB read from dump and rebuilt from web update
                  should work 100%
                  • angel-boy
                    • 550
                    man , i dont know how you are doing this, but its working, God bless you
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Thanks x2, worked here too.
                      A working TV? How boring!
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        hehehe, there is no magic, only hex codes
                        im glad to help, as always
                        dont hesitate to ask for help
                        • angel-boy
                          • 550
                          i still have problems, power up , entering bios, i see all hdd,
                          when i want to install windows, after is restarting its freezing, i cannot turn off from button , only remove power cord
                          If i want to power again, power on and off ,
                          any ideea ?
                          • TheSecondRaid
                            • Mar 2017
                            • Россия
                            Hello, I'm having problem with K95VB, after i changed bios config ( I've swithced off Intel Anti-theft, and (I don't know why) chaged amount of vram to bigger one.) After that changes, I've got a black screen, but it seems like Boot Block still works ( i've inserted usb flash 512m with bios files, and after pressing ctrl+home+power reading begins, but only a few seconds). Can somebody help me with some advice?
                            • nabilgo
                              • May 2016
                              • 303
                              • L.A
                              should work 100%
                              bro thank tou working
                              • TECHO TN
                                • Jan 2024
                                • 68
                                • algeria
                                should work 100%
                                Worked 100% thanks
                                • marcusp
                                  • Apr 2025
                                  • 5
                                  • France
                                  I've 2x UEFI BIOS corrupted on 2x Asus R900 (K95VB version), I've ordered a programmer on Aliexpress, and read different guides on this forum and on winraid.
                                  Until I received my programmer, I wanted to practice on dumped bios, so I've downloaded a version found on this forum. But since I'll to inject my DMI infos I wanted to try BT.exe & BT2.exe from this post.
                                  Unfortunately, each time I'm lauching these apps in Win 11, I'm recceived an error telling me this is a Win16 application :/... is there a way around this problem ?
                                  I've also a problem with FD44Editor when opening dumped K95VB or K95VJ bios files whereas it should be able to open them right ?
                                  Any advice would be appreciated, thanks in advance
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                • peste
                                  • 13600
                                  • ROMANIA
                                  post S/N, full name and model, motherboard model, ,etc.
                                  post the contents of the bios chip even if it is corrupted..
                                  The bios chip must be unsoldered from the board before writing or reading..
                                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                  solder wires between the programmer and the bios chip..
                                  here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                  ​use the HxD program...
                                  read the forum rules..
                                  • marcusp
                                    • Apr 2025
                                    • 5
                                    • France
                                    Thanks for you answer. As I told you, I've still not received the programmer (T48) so I can't read my BIOS chip for now. The mobos are 2x LA-A681P (A letter is missing in the title of this thread).
                                    I've changed the mobo in one of the computer so the S/N on the bottom cover is not correct. That's why I'll extract them from the dumps I'll make in reading the chips.
                                    • marcusp
                                      • Apr 2025
                                      • 5
                                      • France
                                      I"ve received my programmer yesterday, and made a dump of one of my dead mobo.
                                      Until now I've found the offset of the MS key and my S/N, but I can't find my MAC address. Does anyone know what's the offset ?
                                      Here is my dump, the computer was unable to boot, so what do I need to change in order to bring it back to life ? I've read several tutorials and watch many videos, but none of them is for this generation of Asus computer which is pretty old.
                                      Any help would be appreciated, thanks in advance.
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
