Asus X551MA no boot - BIOS
  • rtra
    RuiAlmeida
    • Apr 2015
    • 16
    • Portugal
    I have a MB asus X551MA REV 2.0 tha only show the power led when i press the power button. No start the fan, no image, hdd no start spinning.
    I have 19v on DC jack pins, but i have no clue what to check next.
    Can anyone give me any hints?
    (I'am a beginner on electronics, so i'am here to learn as much as i can)
    Thank's
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Asus X551MA no boot
    Reflash Bios
    • senz1693
      • Jul 2016
      • 11
      • indonesia
      Reflash EC
      • rtra
        RuiAlmeida
        • Apr 2015
        • 16
        • Portugal
        Hi again,
        Finally, I got a minipro to flash my bios chip.
        I desolder the chip from the board and place it into the minipro. Made the read and save the file to have a backup.
        After i download the file from asus site and loaded the file X551MAAS.515 into the minipro and hit "programming" with all the defaults, after a while i got an error like the photo attached.
        I know i'am doing something wrong but i have no idea what. And this is my first time flashing a chip.
        Can anyone give me a hint ?
        • shuc
          • 30
          • Romania
          you need adapter for 1.8V...
          • rtra
            RuiAlmeida
            • Apr 2015
            • 16
            • Portugal
            Hi, thanks for your suggestion, but i have that adapter, it's a 200 mil 8pins.
            First thing i did was read and save what it read. But if i try to write the file read previously i get the same error.
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              try with this working dump
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                did you select good IC? Do you see a chip ID in read ID function?
                What version of MiniPro software do you use? Did you upgrade firmware on device (Tools -> Flash firmware)
                Also try with this .bin file
                ...the quieter you become the more you are able to hear...
                • rtra
                  RuiAlmeida
                  • Apr 2015
                  • 16
                  • Portugal
                  The version I'm using is 6.50. In Tools ->reflash firmware that option is disabled.
                  I can read the chip id with no problem.
                  I tested with your dump file and got the error too...
                  • String2016
                    • Nov 2015
                    • 2229
                    • philippines
                    try uncheck the verify in the options before you start programming
                    • rtra
                      RuiAlmeida
                      • Apr 2015
                      • 16
                      • Portugal
                      Thank you
                      Finally, the file was written
                      So the option to verify isn't necessary?
                      • String2016
                        • Nov 2015
                        • 2229
                        • philippines
                        Originally posted by rtra
                        Thank you
                        It is necessary but when you got an error when flashing you can try uncheck that option to make it complete
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          Yesterday, 05:52 PM
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • lrouw84
                          by lrouw84
                          Hi there,
                          01-28-2023, 01:31 PM
                        • oragano
                          ASUS ex-b250-V7 motherboard bios corrupted - by me
                          by oragano
                          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                          10-17-2024, 02:53 AM
                        • chudofermer
                          Asus Ally rc71l bios
                          by chudofermer
                          Hello!
                          Received Asus Ally rc71l with the wrong bios.
                          Have the original package and all serial numbers.
                          Can anyone help me understand what is wrong?
                          Condition:
                          Received with an original box with all serial numbers
                          Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                          Got the flash dump, nothing found on DMI section
                          No Windows key, just key ID on the box
                          What is done:
                          1. Flash the latest bios version with serial numbers...
                          03-05-2025, 05:42 AM
