Asus X551MA no boot - BIOS
  • rtra
    RuiAlmeida
    • Apr 2015
    • 16
    • Portugal
    I have a MB asus X551MA REV 2.0 tha only show the power led when i press the power button. No start the fan, no image, hdd no start spinning.
    I have 19v on DC jack pins, but i have no clue what to check next.
    Can anyone give me any hints?
    (I'am a beginner on electronics, so i'am here to learn as much as i can)
    Thank's
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Asus X551MA no boot
    Reflash Bios
    • senz1693
      • Jul 2016
      • 19
      • indonesia
      Reflash EC
      • rtra
        RuiAlmeida
        • Apr 2015
        • 16
        • Portugal
        Hi again,
        Finally, I got a minipro to flash my bios chip.
        I desolder the chip from the board and place it into the minipro. Made the read and save the file to have a backup.
        After i download the file from asus site and loaded the file X551MAAS.515 into the minipro and hit "programming" with all the defaults, after a while i got an error like the photo attached.
        I know i'am doing something wrong but i have no idea what. And this is my first time flashing a chip.
        Can anyone give me a hint ?
        • shuc
          • 30
          • Romania
          you need adapter for 1.8V...
          • rtra
            RuiAlmeida
            • Apr 2015
            • 16
            • Portugal
            Hi, thanks for your suggestion, but i have that adapter, it's a 200 mil 8pins.
            First thing i did was read and save what it read. But if i try to write the file read previously i get the same error.
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              try with this working dump
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                did you select good IC? Do you see a chip ID in read ID function?
                What version of MiniPro software do you use? Did you upgrade firmware on device (Tools -> Flash firmware)
                Also try with this .bin file
                ...the quieter you become the more you are able to hear...
                • rtra
                  RuiAlmeida
                  • Apr 2015
                  • 16
                  • Portugal
                  The version I'm using is 6.50. In Tools ->reflash firmware that option is disabled.
                  I can read the chip id with no problem.
                  I tested with your dump file and got the error too...
                  • String2016
                    • Nov 2015
                    • 2242
                    • philippines
                    try uncheck the verify in the options before you start programming
                    • rtra
                      RuiAlmeida
                      • Apr 2015
                      • 16
                      • Portugal
                      Thank you
                      Finally, the file was written
                      So the option to verify isn't necessary?
                      • String2016
                        • Nov 2015
                        • 2242
                        • philippines
                        Originally posted by rtra
                        Thank you
                        It is necessary but when you got an error when flashing you can try uncheck that option to make it complete
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • futadmytro
                          Asus g713qm-es94 stuck on boot bios problem
                          by futadmytro
                          sn^M4NRKD02753616E
                          MB- g533-6050a3250201-MB-A03
                          Stuck on boot after ROG logo, did not enter to bios
                          In flash bios , laprop boot but have video issue
                          orig bios...
                          06-25-2025, 08:07 AM
                        • kenkaniff
                          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                          by kenkaniff
                          Product Name: HP Pro x360 Fortis 11-inch G9
                          System BIOS: U94 Ver.01.08.00 10/06/2023
                          Serial Number: 5CG31946F5
                          SKU Number: 85W05EC#AK8
                          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                          I needed to remove bios password...
                          10-01-2025, 04:32 AM
                        • lrouw84
                          by lrouw84
                          Hi there,
                          01-28-2023, 01:31 PM
