Bios HP 840 g1 - 6050A2560201-MB-A03
    Re: Bios HP 840 g1 - 6050A2560201-MB-A03
    Originally posted by dakiza View Post
    Can someone repair these files? Is a dump from 840 g1 MB -6050a2560201-mb-a03 from dead board. I want to flash it on another same board. I think is not compatible because of chip matching and S/N number. Thanks
    Here's your New Bios, try it and let me know.
    Serial Number: CNU4289FVR.
    Put your 2MB chip back.
    all donations are welcome,
      Re: Bios and Schematic HP 840 g1 - 6050A2560201-MB-A03
      Originally posted by emr2000 View Post
      try
      10x All OK
        BRAND: HP Elitebook 840 G1
        S/N: CNU407BTC8
        PRODUCT ID: H5G30EA#ABN
        BOARD NO: 6050A2560201-MB-A03
        PROCESSOR: SR170
        PROBLEM: NEEDS A CLEAN ME BIOS BUT THE 2MB CHIP IS MISSING
        REQUESTING THE 2MB FILE ALSO.
        ATTACHED IS THE ORIGINAL 16MB FILE.
          Originally posted by dennis akumu View Post
          brand: Hp elitebook 840 g1
          s/n: Cnu407btc8
          product id: H5g30ea#abn
          board no: 6050a2560201-mb-a03
          processor: Sr170
          problem: Needs a clean me bios but the 2mb chip is missing
          requesting the 2mb file also.
          Attached is the original 16mb file.
          anybody who can help
            any help here pliizzz ill be gratefull.
              I have 840 g1 that is extremely slow. Can take upto 5 minutes on logo, reboot take 5 minutes before it boots windows it will take up to 30minutes. What might be the problem, i have attached the back up bios if it might help solve.
                Here's your New BIOS, try it and give me results.
                Serial Number: CNU413CL89.
                  Thank you hardware 1 it displays but still has same issue, takes hours to respond
                    Also if i forcefully power it off with the power button it goes off, the power button led remain on but the wifi and sound one go off, if i try to power it on again it will not power on unless i disconnect and reconnect the charger
                      try post #38,72....write both bios..
                        Same behavior but they display
                          remove everything from it (DVD, WIFI, HDD, etc.) and turn it on, see if it lags..
                            No change
                              Dear Frends can any one clean me this laptop tooooo late
                                hi please i wantto unlock my bios 6050a2559101-mb-a02 hp 840 g1
                                  try..
                                    Read the rules before posting:
                                    BIOS guides, methods, resources and tools
                                    Password removal by laptop brand
                                    Become a Badcaps supporter
                                    Thanks to all supporters.​
                                      try..
                                      thankyou its ok
                                        HP EliteBook 840 G1 6050A2560201-MB-A03
                                        could someone fix my BIOS? Already tried to clean ME on my own, no success.
                                        Laptop does not turn on at all, only front LED blinks when plugged in and charging. When I solder both chips from a scrap 840G1 board, it turns on at least but blank sceen and fan on fullspeed, so I assume my original BIOS is corrupt.
                                        Attached is the 16MB, should I dump the 2MB chip also?
                                        Thanks!
                                          Re: HP EliteBook 840 G1 6050A2560201-MB-A03
                                          Thanks!
                                          try..
