Asus x202e need bios dump.
  • Marco_compucell
    • Feb 2012
    • 67
    • South Africa
    Re: Asus x202e need bios dump.
    thank you
    • MMs_ms
      • Jul 2016
      • 30
      • egypt
      Thank you
      • lordmuken
        • May 2018
        • 54
        • Philippines
        thanks for the bios!
        • azerkode
          • Oct 2013
          • 5
          • Indonesia
          thanksssssssssssssss
          • HDST
            • Mar 2018
            • India
            Thanks Bro
            • aboalshood
              • Feb 2015
              • 9
              • hara
              #26
              Thank you brother The file works successfully after the experiment
              • ossocomp
                • Jan 2016
                • indonesia
                #27
                thank you
                • laptopbn
                  • Jul 2016
                  • 71
                  • Viet Nam
                  #28
                  thanks
                  • qonma
                    Kuli Solder
                    • Jun 2017
                    • 184
                    • INDONESIA
                    #29
                    thank you very much
                    • teknikpc
                      technical
                      • Dec 2016
                      • 62
                      • Türkiye
                      #30
                      thanks
                      • MUHİ26
                        • Oct 2017
                        • 4
                        • TÜRKİYE
                        #31
                        thank you
                        • tomazz
                          • Jul 2016
                          • Serbia
                          #32
                          • dahnking
                            • Apr 2018
                            • 258
                            • kenya
                            #33
                            Originally posted by kazia
                            here the dump...
                            Thanks alot,
                            100% working
                            • ElecPCTech
                              • Mar 2016
                              • 9
                              • Portugal
                              #34
                              here the dump...
                              Thanks for the dump.
                              • mus
                                • Apr 2017
                                • 12
                                • france
                                #35
                                Thank you so much !
                                • coicoicoi
                                  • Nov 2022
                                  • 12
                                  • philippines
                                  #36
                                  thank you
                                  • tatanet01
                                    • Sep 2018
                                    • maroc
                                    #37
                                    Thank you.
                                    • djharold
                                      • Aug 2015
                                      • 241
                                      • COLOMBIA
                                      #38
                                      here the dump...
                                      thanks a lot
                                      • svadikn
                                        PC-expert
                                        • Jul 2024
                                        • 15
                                        • Poland
                                        #39
                                        thanks bro
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • kodox
                                          Asus ExpertBook B1400CB Bios Dump Needed
                                          by kodox
                                          need original bios dump, original bios has flashed by other technician before me.
                                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                          unit info:
                                          Model: Asus ExpertBook B1400CBA-0711A1235U
                                          S/N: R6NXNZ006657238
                                          CN: 7F6F
                                          Mainboard Code: B1500CBA R2.1...
                                          08-16-2025, 12:20 PM
