Asus x202e need bios dump.
  • Marco_compucell
    • Feb 2012
    • 67
    • South Africa
    Re: Asus x202e need bios dump.
    thank you
    • MMs_ms
      • Jul 2016
      • 30
      • egypt
      Thank you
      • lordmuken
        • May 2018
        • 53
        • Philippines
        thanks for the bios!
        • azerkode
          • Oct 2013
          • 5
          • Indonesia
          thanksssssssssssssss
          • HDST
            • Mar 2018
            • India
            Thanks Bro
            • aboalshood
              • Feb 2015
              • 9
              • hara
              #26
              Thank you brother The file works successfully after the experiment
              • ossocomp
                • Jan 2016
                • indonesia
                #27
                thank you
                • laptopbn
                  • Jul 2016
                  • 71
                  • Viet Nam
                  #28
                  thanks
                  • qonma
                    Kuli Solder
                    • Jun 2017
                    • 184
                    • INDONESIA
                    #29
                    thank you very much
                    • teknikpc
                      technical
                      • Dec 2016
                      • 62
                      • Türkiye
                      #30
                      thanks
                      • MUHİ26
                        • Oct 2017
                        • 4
                        • TÜRKİYE
                        #31
                        thank you
                        • tomazz
                          • Jul 2016
                          • Serbia
                          #32
                          • dahnking
                            • Apr 2018
                            • 258
                            • kenya
                            #33
                            Originally posted by kazia
                            here the dump...
                            Thanks alot,
                            100% working
                            • ElecPCTech
                              • Mar 2016
                              • 9
                              • Portugal
                              #34
                              here the dump...
                              Thanks for the dump.
                              • mus
                                • Apr 2017
                                • 12
                                • france
                                #35
                                Thank you so much !
                                • coicoicoi
                                  • Nov 2022
                                  • 12
                                  • philippines
                                  #36
                                  thank you
                                  • tatanet01
                                    • Sep 2018
                                    • maroc
                                    #37
                                    Thank you.
                                    • djharold
                                      • Aug 2015
                                      • 241
                                      • COLOMBIA
                                      #38
                                      here the dump...
                                      thanks a lot
                                      • svadikn
                                        PC-expert
                                        • Jul 2024
                                        • 15
                                        • Poland
                                        #39
                                        thanks bro
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Anchar777
                                          ASUS P1412CE need BIOS DUMP
                                          by Anchar777
                                          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                          06-26-2025, 03:39 AM
