Asus x202e need bios dump.
+ More Options
Posts
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    asus x202e rev 2.0 , i need bios dump.. please help me..
    thanks in advance ..
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Asus x202e need bios dump.
    here the dump...
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      Originally posted by kazia
      here the dump...
      thanks a lot men,,,
      • vandehaai
        • Nov 2013
        • 24
        • Nederland
        thank you
        • bajinchi
          • Jul 2012
          • 14
          • Argentina
          Thank you!!!
          • katfish
            • Jul 2016
            • 76
            Older post. But thanks ... worked great here.
            • inter_cyber
              • May 2014
              • 8
              • turkey
              thanks
              • Watz
                • Sep 2014
                • 21
                • Kenya
                Thank you
                • bhuwan_vibha
                  • Feb 2016
                  • 10
                  • india
                  thanks...
                  • rein2017
                    • Jun 2017
                    • 35
                    • Philippines
                    • boss juben
                      • Oct 2016
                      • 37
                      • philippines
                      thanks
                      • x_menekse
                        • May 2016
                        • 11
                        • Turkey
                        very very thanks. its worked.
                        • fyaagoub
                          • 269
                          • maroc
                          very thanks
                          • casaba
                            • Apr 2014
                            • 25
                            • morokko
                            thanks
                            • fgh34
                              • Sep 2017
                              • 6
                              • Portugal
                              thank you very much
                              • enversefa
                                • Oct 2016
                                • 21
                                • istanbul
                                Thank you so much
                                • rager007
                                  • Feb 2016
                                  • 106
                                  • Usa
                                  Thank you so much
                                  • yasiu_kam
                                    • Nov 2017
                                    • Poland
                                    Thanks man, everything works fine.
                                    • oman ame
                                      • indonesia
                                      thanks bro...
                                      • turgay
                                        • Aug 2016
                                        • türkiye
                                        teşekkürler
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Anchar777
                                          ASUS P1412CE need BIOS DUMP
                                          by Anchar777
                                          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                          06-26-2025, 03:39 AM
