Asus bios conversion
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    hi,
    It's possible to conver an asus bios xxxx.203 format to bin ?
    thanks
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Asus bios conversion
    Originally posted by jasko_jacker
    hi,
    thanks
    attach bios file pls
    • khaahk
      • Dec 2013
      • 765
      • Estonia
      sometimes this helps:
      type "ren xxx.203 xxx.bin" in command prompt in the directory where the fail is.
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        The problem is that the size of bios from .207 extension (asus G75vw) is less in size (6.1 MB) respect the dump I made, 8 MB
        With some hp bios I use phoenix tool that decrypt it and after I remove some byte with hex editor .
        Only way is to pay a bios dump on internet because no one have it for free ?
        thanks
        • khaahk
          • Dec 2013
          • 765
          • Estonia
          Because Asus does not upload the complete dump, only the bios part of it. ME is missing. That is if you can read the remaining bios from the chip you can take the me part add it with intel tools and create a complete dump. Or find it in a forum.
          As this one maybe helps:
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            post old dump and ill fix it
            Im Back... sort of...
            • marc23
              • Nov 2020
              • philippines
              sir dump zx53v bios 8mb
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • lrouw84
                Asus vivobook s510ua bios changed to x510un
                by lrouw84
                Hi there,
                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                01-28-2023, 01:31 PM
