Bios needed for Dell E6320
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Bios needed for Dell E6320
    try this
    Im Back... sort of...
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      This one is la-6611p on board backup bios dump.
      • naeemshahzad
        • Jan 2015
        • 129
        • uae
        Power is direct on and no display and power switch is also not working . Also i change the PCH Chip BD82QM67 SLJ4M . temperature is normal processor voltage is also there 1.1v and 0.82v it's sounds like bios is not working .
        • erwing07
          • Feb 2016
          • 10
          • Mexico
          Re: Dell E6430 BIOS help needed
          Tanks for the info
          • bluestone
            • Jun 2011
            • 343
            • Ghana
            having the same issue after flash, were you able to fix yours?
            • tferi
              • May 2016
              • Romania
              #26
              Hi!
              Can somebody help me to change service tag in a Latitude E6430 EC BIOS.
              Both, main and EC flash are faulty, I have booth dump files in BIN, but needs to put back the original service and asset tag in the new chips.
              Thank you!
              • mitesh
                • Oct 2014
                • 8
                • india
                #27
                dell E6320 how to hard reset power on password
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  #28
                  Originally posted by ala_borbe
                  try this
                  thanks it works..
                  • balobi
                    • Jan 2015
                    • 88
                    • phillippines
                    #29
                    Pls help... somebody have dell latitude PAL70 LA-6612P REV1.0 BIOS FILES? MINE HAS PASSWORD.
                    • seliarizwan
                      • Apr 2013
                      • 10
                      • India
                      #30
                      thks
                      • Pascal Komlassan
                        • Jan 2017
                        • 809
                        • TOGO
                        #31
                        try this
                        thank's bro
                        • fyaagoub
                          • Dec 2016
                          • 269
                          • maroc
                          #32
                          thank's bro
                          • mazloum
                            • Sep 2012
                            • 499
                            • Lebanon
                            #33
                            try this
                            thanks works good
                            • tanaka21
                              • Jul 2021
                              • Romania
                              #34
                              Re: Identify Power Management chip DELL E7240 (LA-9431P)
                              Originally posted by Rhork
                              I replaced the chip and now everything is ok, thanks for identifying the chip
                              Hi, I know that might be out of your topic, but I`m a newcomer and I wondered if you can give me a helping hand.
                              I made some changes in BIOS - DELL LATITUDE 6320 (booting options UEFI/LEGACY) unchecking some options. After restart laptop is stuck in logo, pressing F2/f12 showing just Preparing to... and that's all.
                              Is there any chance to clear CMOS/reset BIOS. I disassembled everything for 2 days, no reset.
                              Merci beacoup!
                              • alirafee
                                • Jun 2015
                                • 80
                                • iran
                                #35
                                hi
                                give me reset code for dell latitude e6320
                                Service tag: 6HJPBS1-1D3B
                                THANKS
                                  • 20977
                                  Originally posted by alirafee
                                  hi
                                  THANKS
                                  https://www.badcaps.net/forum/showpo...42&postcount=4
                                  • Alassane
                                    • Oct 2018
                                    • 65
                                    • MALI
                                    #37
                                    try this
                                    thanks you
                                    • bmxlovah
                                      Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                                      by bmxlovah
                                      My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                                      11-24-2022, 06:29 AM
                                    • trix11
                                      Dell Precision T1650 MT Workstation bricked after BIOS update
                                      by trix11
                                      I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                      - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                      - Dell Precision T1650 mid tower Workstation
                                      - Xeon E3-1225 V2
                                      - 32Gb PC3-12800E RAM
                                      - 4Tb SATA HDD
                                      - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                      I see now that others have experienced like issues e.g.:
                                      - https://www.dell.com/community/Prec...
                                      10-24-2022, 10:35 PM
                                    • urad29
                                      Dell Inspiron 15 3511 Bios Needed
                                      by urad29
                                      I have a Dell Inspiron 15 3511 (Service tag: FY3C9T3) which is not booting past the Dell logo and I cannot enter the BIOS by pressing F2.
                                      I therefore believe that the BIOS is corrupted.
                                      I have spent some time trying to figure it all out as I have managed to reprogram BIOS's in the past.
                                      The motherboard has two chips, one is a 25Q64JVSIQ and the other is a 25Q128JVSQ.
                                      Firstly, how do I know which one is the BIOS, or are they both BIOS (have only worked on single BIOS boards).
                                      Secondly, I cannot seem to get a bin file or the like from the BIOS exe...
                                      03-21-2023, 03:46 PM
                                    • malishah83
                                      Dell XPS 9305 Bios Needed
                                      by malishah83
                                      Hello Sir, I have Dell XPS 9305 i5 11th Generation with Bios Problem, after replace bios, Display comes after 30 seconds aproxx, but SSD not detected. I have attached both bios 1 is original with no display and second bios with late display and no SSD detect. Please clean ME with SSD detection....
                                      09-09-2023, 04:34 PM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
