Bios needed for Dell E6320
  • t4ure4n
    • Sep 2013
    Can some one please help me with the master password for DELL e6430 BIOS password.
    The BIOS is locked with admin password, without which I can't even change the boot sequence.
    The service tag is 9K7GWW1-1D3B
    The keyboard is QWERTY
    Thanks in advance
  • dj_ricoh
    • 2073
    • uk
    Re: Dell E6430 BIOS help needed
    if you manage to find somewhere plzzx tell me to
    • lord
      • May 2011
      • 319
      • Croatia
      I think there is similar threads with same problem, so please use search. If i manage to find extra time, i will search it for you, but it would be at the end of the day.
      If everything else fails, buy the BIOS chip on ebay and replace it. It is a small cost solution.
      • lord
        • May 2011
        • 319
        • Croatia
        Here you go, it was just under this thread :P
        https://www.badcaps.net/forum/showthread.php?t=16965
        https://www.badcaps.net/forum/showthread.php?t=26981
        • t4ure4n
          • Sep 2013
          Originally posted by lord
          Here is my research until now.
          Software solution
          1. Keygen: There is no public/free software solution for systems with Service Tag ending 1D3B.
          2. BIOS downgrade You have to downgrade to a previous edition of the BIOS whose last 4 letters of the Service Tag is 595B/D35B/2A7B/A95B etc. Then follow this free online service based on Dogbert's findings.
            The process (Works for D630... needs to be tested for E6430.. ) is as follows:
            • Take HDD out first or it can lock it.
            • Find .HDR file for old version of BIOS for example for Dell D630 its BRIS***.HDR Where BRIS is short name for motherboard dell codename BRISBANE. and *** = A08 version.
            • Put this file in USB
            • How to make HDR? On most dell systems, type the following in administrative command prompt
              Code:
              bios.exe /writehdrfile
            • Now take battery and power cord out, plug in usb.
            • Hold END and POWER Button while pluging in power cord.
            • Now battery light starts blinking red green purple means its flashing. 2 minutes and it shuts off.
            • Now its A08 and password should work.
          Hardware solution
          1. First solution presented by dycc in the post here requires taking the CMOS chip off the mobo and using the programmer to over write it with a clean image (.BIN file). The tool costs around £26 in UK but I have no idea where to get the clean .BIN file for E6430.
          2. Second option is uses a Ultimate Boot CD to clear the CMOS using the WipeCMOS app.
          I am tempted to try the second option, but In my case, booting from CD/ROM is disabled in BIOS.
          My boot sequence is 1. NIC 2. HDD 3. USB HD...
          If someone can help me with putting the Ultimate Boot CD image on USB to boot from it I may be able to test it.
          • Techn0pro
            • Oct 2013
            I have a E6430 which was also locked. It also had the ***-1D3B lock code. First of all the easiest way to fix this would be to chat with a Dell tech support rep who was able to take my code and generate an unlock code. It was free since it is still under warranty. This will save you a lot of headache. you can try the code I was given but I'm pretty sure its specific to the service tag number. Good luck!
            1Uv6017IUZN36T1h It is case sensitive and I had to hold ctrl while pressing enter.
            • zbudo
              • Oct 2013
              • 7
              • Austria
              need bios for E6320
              l need clean bios for dell E6320
              • dycc
                Vision
                • Nov 2011
                • 624
                • Côte d'Ivoire
                Re: need bios for E6320
                What is the size of your bios ????
                • repairs
                  • Nov 2013
                  • 10
                  • india
                  HI
                  i need bios password reset tool for dell latitude e6320 pls help me
                  • dj_ricoh
                    • 2073
                    • uk
                    Originally posted by repairs
                    HI
                    don`t do that!
                    • repairs
                      • Nov 2013
                      • 10
                      • india
                      hi i have same model but it have bios password how to remove
                      • dj_ricoh
                        • 2073
                        • uk
                        you remove the bios with this tool
                        https://www.badcaps.net/forum/showth...hlight=utility
                        • Taylor3
                          • Mar 2014
                          • Norway
                          I need urgent help for my E6320.
                          7SNFCS1-1D3B
                          Anybody..please ???
                          • alfa20fr
                            • Jan 2012
                            • 34
                            7SNFCS1-1D3B
                            Anybody..please ???
                            her dump
                            • Taylor3
                              • Mar 2014
                              • Norway
                              Thank you.. Please advice on how to use this file..I am a novice when it comes to .rar files..
                              • dj_ricoh
                                • 2073
                                • uk
                                install WinRar, open with that program and just drag and drop
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  La-6621p r1.0
                                  check ok working.
                                  • naeemshahzad
                                    • Jan 2015
                                    • 129
                                    • uae
                                    Bios dump needed for dell e6320 mainboard is LA-6611p rev :1.0 thanks
                                    • imranromi
                                      • Jan 2015
                                      • 1288
                                      • Pakistan
                                      Re: Bios needed for Dell E6320
                                      try this working.
                                      • naeemshahzad
                                        • Jan 2015
                                        • 129
                                        • uae
                                        it is not for LA-6611P board it working on LA-6621P mainboard .is any one have bios for LA-6611P bios dump
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • Aarush653
                                          Dell Latitude 5340 corrupt bios - clean bios needed
                                          by Aarush653
                                          Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
                                          Worked good before failed flash now won't power at all.
                                          May have been a bad connection.
                                          Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
                                          32mb chip - 25Q256JVEN
                                          Attach Dell Bios Update file v1.14 - original Dell update...
                                          10-14-2024, 04:28 PM
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
                                        • bmxlovah
                                          Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                                          by bmxlovah
                                          My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                                          11-24-2022, 06:29 AM
