Da0lx8mb6d1 REV.D bios dump need
  • whitevolf
    • Feb 2014
    • 123
    • TÜRKİYE
    Re: Da0lx8mb6d1 REV.D bios dump need
    thanks
    • Umadbro
      • Jul 2018
      • 65
      • Portugal
      Hi. I have the following machine:
      HP Pavilion dv6-3156sg
      DA0LX8MB6D1 REV: D
      AMD CPU
      Turns on, black screen, CAPS flashing white every 4 seconds, wifi is solid amber.
      There was a little corrosion between two pads on the keyboard FPC, which I cleaned. No short. Tested bios from post #2 but no luck. Tried slight reflow to GPU as reported to be a common issue on this model, no luck either.
      I am unsure if the dumps I used are propper for this mb, as there are many different version I can find on the internet.
      May someone have a look and maybe sort my backup? Thank you in advance.
      • peste
        • 13629
        • ROMANIA
        DA0LX8MB6D1 REV: D
        AMD CPU
        bios extracted from the HP site update
        DMI 20000 - 200FF
        • Umadbro
          • Jul 2018
          • 65
          • Portugal
          DMI 20000 - 200FF
          Hi, and thank you. I tried to flash this file but had no luck, the machine remains in the same state.
          Once again I tested all major coils/caps and no apparent shorts, the liquid damage between the kb points doesn't seem to have damaged adjacent capacitors. I will try to find the right schematic for this board. Could it be CPU?
            • 21936
            This is the bios requests section only. If you want more help start a new thread in the main laptop forum.
            • Umadbro
              • Jul 2018
              • 65
              • Portugal
              #26
              Will do. Thanks.
              • prypoy
                • Jul 2019
                • Украина
                #27
                • whitevolf
                  • Feb 2014
                  • 123
                  • TÜRKİYE
                  #28
                  thank you
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    by haitham sharabati
                    Hello engineers 😀,
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    💀 Problem:😅
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
