Da0lx8mb6d1 REV.D bios dump need
  • whitevolf
    • Feb 2014
    • 122
    • TÜRKİYE
    Re: Da0lx8mb6d1 REV.D bios dump need
    thanks
    • Umadbro
      • Jul 2018
      • 65
      • Portugal
      Hi. I have the following machine:
      HP Pavilion dv6-3156sg
      DA0LX8MB6D1 REV: D
      AMD CPU
      Turns on, black screen, CAPS flashing white every 4 seconds, wifi is solid amber.
      There was a little corrosion between two pads on the keyboard FPC, which I cleaned. No short. Tested bios from post #2 but no luck. Tried slight reflow to GPU as reported to be a common issue on this model, no luck either.
      I am unsure if the dumps I used are propper for this mb, as there are many different version I can find on the internet.
      May someone have a look and maybe sort my backup? Thank you in advance.
      • peste
        • Dec 2016
        • 12822
        • ROMANIA
        DA0LX8MB6D1 REV: D
        AMD CPU
        bios extracted from the HP site update
        DMI 20000 - 200FF
        • Umadbro
          • Jul 2018
          • 65
          • Portugal
          DMI 20000 - 200FF
          Hi, and thank you. I tried to flash this file but had no luck, the machine remains in the same state.
          Once again I tested all major coils/caps and no apparent shorts, the liquid damage between the kb points doesn't seem to have damaged adjacent capacitors. I will try to find the right schematic for this board. Could it be CPU?
            • 20933
            This is the bios requests section only. If you want more help start a new thread in the main laptop forum.
            • Umadbro
              • Jul 2018
              • 65
              • Portugal
              #26
              Will do. Thanks.
              • prypoy
                • Jul 2019
                • 3
                • Украина
                #27
                • whitevolf
                  • Feb 2014
                  • 122
                  • TÜRKİYE
                  #28
                  thank you
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    Yesterday, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • MDSI
                    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                    by MDSI
                    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                    Details:
                    Model : HP OMEN 17-an012nf
                    Motherboard Part Number : DAG3BAMBAF0 REV : F
                    Serial Number (S/N) : 5CD7280D51
                    BIOS chip : Winbond W25Q64VSIQ
                    Programmer : EZP2023+
                    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                    I already...
                    07-28-2025, 07:11 AM
