Da0lx8mb6d1 REV.D bios dump need
  • whitevolf
    • Feb 2014
    • 122
    • TÜRKİYE
    Re: Da0lx8mb6d1 REV.D bios dump need
    thanks
    • Umadbro
      • Jul 2018
      • 65
      • Portugal
      Hi. I have the following machine:
      HP Pavilion dv6-3156sg
      DA0LX8MB6D1 REV: D
      AMD CPU
      Turns on, black screen, CAPS flashing white every 4 seconds, wifi is solid amber.
      There was a little corrosion between two pads on the keyboard FPC, which I cleaned. No short. Tested bios from post #2 but no luck. Tried slight reflow to GPU as reported to be a common issue on this model, no luck either.
      I am unsure if the dumps I used are propper for this mb, as there are many different version I can find on the internet.
      May someone have a look and maybe sort my backup? Thank you in advance.
      • peste
        • Dec 2016
        • 12755
        • ROMANIA
        DA0LX8MB6D1 REV: D
        AMD CPU
        bios extracted from the HP site update
        DMI 20000 - 200FF
        • Umadbro
          • Jul 2018
          • 65
          • Portugal
          DMI 20000 - 200FF
          Hi, and thank you. I tried to flash this file but had no luck, the machine remains in the same state.
          Once again I tested all major coils/caps and no apparent shorts, the liquid damage between the kb points doesn't seem to have damaged adjacent capacitors. I will try to find the right schematic for this board. Could it be CPU?
            • 20818
            This is the bios requests section only. If you want more help start a new thread in the main laptop forum.
            • Umadbro
              • Jul 2018
              • 65
              • Portugal
              #26
              Will do. Thanks.
              • prypoy
                • Jul 2019
                • 3
                • Украина
                #27
                • whitevolf
                  • Feb 2014
                  • 122
                  • TÜRKİYE
                  #28
                  thank you
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • MDSI
                    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                    by MDSI
                    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                    Details:
                    Model : HP OMEN 17-an012nf
                    Motherboard Part Number : DAG3BAMBAF0 REV : F
                    Serial Number (S/N) : 5CD7280D51
                    BIOS chip : Winbond W25Q64VSIQ
                    Programmer : EZP2023+
                    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                    I already...
                    07-28-2025, 07:11 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
