Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello friends
    I have here a sony laptop with corrupted bios !
    Model is : Sony Vaio SVF 1521A6EW
    Motherboard is : DA0HK9MB6D0 REV.D
    I already tested a file found on this forum, it doesn't work and it's worse then the actual corrupted!
    Here the dump :
    https://mega.nz/#!fVFEXLJD!um21wOz_z...3fIuN1C7qVqG8g
    Please help guys
  • ivanxxx
    • Nov 2012
    • 10
    • Croatia
    Re: Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
    try this one
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      try this
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Thank you very much guys, you are the best !
        I didn't test the above bios, but i'm sure that they work.
        I've received a good dump from a russian forum.
        Thanks again
        • TossDon
          AKA Masood
          • Jun 2013
          • 26
          Please post the working BIOS so some one can use it.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            The one from post #2 is the same i used and worked.
            • Nasir Raja
              • Mar 2014
              • 21
              • United Kingdom
              Above Ivanxxx one dump is working but language is polish or Russian.
              Thanks guys
              • rata@abv.bg
                • Oct 2015
                • 4
                • Bulgaria
                both dumps working fine...first one is on czech language, 2nd is spanish
                thanks
                • walid1992
                  • May 2016
                  • 35
                  • tripoly
                  thank you
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    Originally posted by ivanxxx
                    try this one
                    is this bios for DA0HK9MB6D0 REV: D or for DA0HK9MB6D0 REV:E ?
                    i want to flash this board : DA0HK9MB6D0 REV: D
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      i think passete has confirm if ivanxxx file worked with his board, his board same with your board...
                      • babak
                        • Jul 2016
                        • Iran
                        Hi evry one I need bios for Sony SVF14NA da0f12mb6d0
                        can you help me?
                        • arcssssc
                          • Feb 2016
                          • 4
                          • azerbaijan
                          THANKS Ivanxxx
                          • cihancyber
                            • Mar 2017
                            • 22
                            • tejhi
                            thanks
                            • elaamraouiyouness
                              • Feb 2017
                              • 9
                              • morroco
                              thank you
                              • eccoqualamail
                                • Jun 2017
                                • italy
                                Originally posted by elaamraouiyouness
                                thank you
                                hallo, can u help me re-programming same bios?
                                tks
                                • dolunay79
                                  • Oct 2016
                                  • 18
                                  • turkey
                                  • jonaspc
                                    • Nov 2017
                                    • Brazil
                                    Very very THANKS Ivanxxx!!!
                                    you save day today!
                                    • reigneilmax
                                      • Jan 2017
                                      • 9
                                      • philippines
                                      thanks for sharing...god bless u
                                      • Kamar
                                        • May 2016
                                        • 8
                                        • india
                                        thanksssssssssssssssssssssss
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
