Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello friends
    I have here a sony laptop with corrupted bios !
    Model is : Sony Vaio SVF 1521A6EW
    Motherboard is : DA0HK9MB6D0 REV.D
    I already tested a file found on this forum, it doesn't work and it's worse then the actual corrupted!
    Here the dump :
    https://mega.nz/#!fVFEXLJD!um21wOz_z...3fIuN1C7qVqG8g
    Please help guys
  • ivanxxx
    • Nov 2012
    • 10
    • Croatia
    Re: Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
    try this one
    • imranromi
      • Jan 2015
      • 1290
      • Pakistan
      try this
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Thank you very much guys, you are the best !
        I didn't test the above bios, but i'm sure that they work.
        I've received a good dump from a russian forum.
        Thanks again
        • TossDon
          AKA Masood
          • Jun 2013
          • 26
          Please post the working BIOS so some one can use it.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            The one from post #2 is the same i used and worked.
            • Nasir Raja
              • Mar 2014
              • 21
              • United Kingdom
              Above Ivanxxx one dump is working but language is polish or Russian.
              Thanks guys
              • rata@abv.bg
                • Oct 2015
                • 4
                • Bulgaria
                both dumps working fine...first one is on czech language, 2nd is spanish
                thanks
                • walid1992
                  • May 2016
                  • 36
                  • tripoly
                  thank you
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    Originally posted by ivanxxx
                    try this one
                    is this bios for DA0HK9MB6D0 REV: D or for DA0HK9MB6D0 REV:E ?
                    i want to flash this board : DA0HK9MB6D0 REV: D
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      i think passete has confirm if ivanxxx file worked with his board, his board same with your board...
                      • babak
                        • Jul 2016
                        • Iran
                        Hi evry one I need bios for Sony SVF14NA da0f12mb6d0
                        can you help me?
                        • arcssssc
                          • Feb 2016
                          • 4
                          • azerbaijan
                          THANKS Ivanxxx
                          • cihancyber
                            • Mar 2017
                            • 22
                            • tejhi
                            thanks
                            • elaamraouiyouness
                              • Feb 2017
                              • 9
                              • morroco
                              thank you
                              • eccoqualamail
                                • Jun 2017
                                • italy
                                Originally posted by elaamraouiyouness
                                thank you
                                hallo, can u help me re-programming same bios?
                                tks
                                • dolunay79
                                  • Oct 2016
                                  • 18
                                  • turkey
                                  • jonaspc
                                    • Nov 2017
                                    • Brazil
                                    Very very THANKS Ivanxxx!!!
                                    you save day today!
                                    • reigneilmax
                                      • Jan 2017
                                      • 9
                                      • philippines
                                      thanks for sharing...god bless u
                                      • Kamar
                                        • May 2016
                                        • 8
                                        • india
                                        thanksssssssssssssssssssssss
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
