Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello friends
    I have here a sony laptop with corrupted bios !
    Model is : Sony Vaio SVF 1521A6EW
    Motherboard is : DA0HK9MB6D0 REV.D
    I already tested a file found on this forum, it doesn't work and it's worse then the actual corrupted!
    Here the dump :
    https://*******/#!fVFEXLJD!um21wOz_z...3fIuN1C7qVqG8g
    Please help guys
  • ivanxxx
    • Nov 2012
    • 10
    • Croatia
    Re: Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
    try this one
    • imranromi
      • Jan 2015
      • 1298
      • Pakistan
      try this
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Thank you very much guys, you are the best !
        I didn't test the above bios, but i'm sure that they work.
        I've received a good dump from a russian forum.
        Thanks again
        • TossDon
          AKA Masood
          • Jun 2013
          • 26
          Please post the working BIOS so some one can use it.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            The one from post #2 is the same i used and worked.
            • Nasir Raja
              • Mar 2014
              • 21
              • Gym, football, car modification
              Above Ivanxxx one dump is working but language is polish or Russian.
              Thanks guys
              • rata@abv.bg
                • Oct 2015
                both dumps working fine...first one is on czech language, 2nd is spanish
                thanks
                • walid1992
                  • May 2016
                  • 36
                  • tripoly
                  thank you
                  • polytek
                    • Dec 2013
                    • 497
                    • TUNISIA
                    • find the solution to the difficult problem
                    Originally posted by ivanxxx
                    try this one
                    is this bios for DA0HK9MB6D0 REV: D or for DA0HK9MB6D0 REV:E ?
                    i want to flash this board : DA0HK9MB6D0 REV: D
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      i think passete has confirm if ivanxxx file worked with his board, his board same with your board...
                      • babak
                        • Jul 2016
                        • Iran
                        Hi evry one I need bios for Sony SVF14NA da0f12mb6d0
                        can you help me?
                        • arcssssc
                          • Feb 2016
                          • azerbaijan
                          THANKS Ivanxxx
                          • cihancyber
                            • Mar 2017
                            • 22
                            • tejhi
                            thanks
                            • elaamraouiyouness
                              • Feb 2017
                              • 9
                              • morroco
                              thank you
                              • eccoqualamail
                                • Jun 2017
                                • italy
                                Originally posted by elaamraouiyouness
                                thank you
                                hallo, can u help me re-programming same bios?
                                tks
                                • dolunay79
                                  • Oct 2016
                                  • 18
                                  • turkey
                                  • jonaspc
                                    • Nov 2017
                                    • Brazil
                                    Very very THANKS Ivanxxx!!!
                                    you save day today!
                                    • reigneilmax
                                      • Jan 2017
                                      • 9
                                      • philippines
                                      thanks for sharing...god bless u
                                      • Kamar
                                        • May 2016
                                        • 8
                                        • india
                                        thanksssssssssssssssssssssss
                                        • Darksands
                                          Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
                                          by Darksands
                                          [SOLVED]
                                          Laptop: Dell Pro 14 Plus, PB14250
                                          Motherboard: PWB CMF34, Rev (A00).
                                          Service Tag: 3YLQ8F4.
                                          CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
                                          BIOS Flash Chip: Winbond 25R512NWEQ.
                                          BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
                                          Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
                                          09-13-2026, 03:15 AM
                                        • Trademark
                                          Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                          by Trademark
                                          I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                          This is NOT a BIOS password removal request.
                                          I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                          Laptop Information
                                          • Model: Acer Predator Triton 16 PT16-51-99GL
                                          • Motherboard: DA0ZQDMB8AE Rev. E
                                          • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                          • Secondary
                                          07-22-2026, 08:57 AM
                                        • Remskiy228
                                          BIOS Dump Request — Lenovo ThinkPad P14s Gen 5 Intel (21G2) (21G3)
                                          by Remskiy228
                                          Hello everyone!
                                          I'm looking for a BIOS dump or assistance with BIOS recovery for my Lenovo ThinkPad P14s Gen 5 Intel.
                                          Laptop specifications:
                                          - Model: Lenovo ThinkPad P14s Gen 5 Intel
                                          - Machine Type: 21G2
                                          - CPU: Intel Core Ultra 5 135H
                                          - GPU: NVIDIA RTX 500 Ada Generation
                                          Problem:
                                          My laptop stopped booting after a firmware update through Lenovo Vantage. It powers on but does not POST or display anything.
                                          What I'm looking for:
                                          Either of the following...
                                          11-13-2026, 09:48 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Junhijam
                                          (Request) MSI PRO B660M-A DDR4 (MS-7D43 Rev 1.0) Bios Dump
                                          by Junhijam
                                          Hi, I'm new to all of this so I hope I'm doing correctly and not breaking any rules.
                                          I need help for my MSI PRO B660M-A DDR4 motherboard BIOS dump.
                                          The motherboard got bricked during BIOS update due to a power cut in my village while updating BIOS. Now the PC is not booting. Fans kept spinning and no display is coming.
                                          A local technician said I need the full BIOS dump/file for this motherboard.
                                          My Motherboard model is:
                                          MS-7D43 REV 1.0
                                          The Bios chip is:
                                          MXIC
                                          MX25U25673GZ4140
                                          Please, if anyone has the same board...
                                          05-29-2026, 03:53 AM
