Asus u36SD rev2.1 bios
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    need bios
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Asus u36SD rev2.1 bios
    try this dump;
    • teqcom
      • Nov 2015
      • 311
      • malasyia
      thx a lot
      • g.dallatorre
        • Oct 2017
        • italy
        thanks!
        • siloe
          • Mar 2020
          • france
          Originally posted by polytek
          try this dump;
          My bios is corrupted.
          Is it a solution to flash this bios on my mother card to retrieve it?
          Thanks a lot
          • peste
            • Dec 2016
            • 13439
            • ROMANIA
            post the bios backup here
            • PinkPumpkin
              • Oct 2020
              • Denmark
              Thanks alot
              • A1yn88
                • Mar 2014
                • 111
                • Romania
                Thanks a lot
                Here is my original bios dump, black screen.
                The bios posted here, the second post, is working but in 16 color mode and I have no option to change. I hope somebody can restore my original bios.
                Thanks.
                • Repdata
                  • May 2020
                  • 67
                  • Deutschland
                  test and give notice
                  • Nawarus
                    • Sep 2021
                    • Kostui
                    Thank you. Helped. Good luck to you in life.
                    • DavidShoe
                      • Apr 2023
                      • Italia
                      perfect
                      there is also the version 206?
                      • Darktenor
                        • Nov 2024
                        • 3
                        • Deutschland
                        Hello, can you repair my bios it won't start anymore
                          • 21691
                          Type the laptop serial number, full name and model, motherboard model, etc.
                          read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                          • Darktenor
                            • Nov 2024
                            • 3
                            • Deutschland
                            This is my first time asking, so I hope I'm doing this correctly:
                            It's an Asus U36S MB Vers. U36SD Serial No.: B9N0AS256521361
                            Model: U36SD-RX179V Check No.: 8012
                            Mainboard U36SD Main Board Rev 2.1
                            The laptop no longer starts
                            • Darktenor
                              • Nov 2024
                              • 3
                              • Deutschland
                              So, my last attempt. The BIOS on my Asus U36SD broke. I installed 8 GB of RAM, a 256 GB SSD, and a new battery. When the battery clicked in, the computer booted directly into the BIOS and then shut down. When I tried to restart the laptop, I only got a black screen. Now I'm desperately searching for a BIOS because the ones on Asus' website don't work. It's an Asus U36SD MB Vers. U36SD Model U36SD-RX179V Serial No.: B9N0AS256521361 Check No.: 8012 Motherboard No.: PN: 60-N58MB1200-E13 It says PT: N0AS1133MB0141039 underneath, and the motherboard says U36SD Rev 2.1.
                              I'm looking for a BIOS for that.
                              • peste
                                • Dec 2016
                                • 13439
                                • ROMANIA
                                the posted bios is corrupt...
                                The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                solder wires between the programmer and the bios chip..
                                here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                try..
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • DynaxSC
                                  by DynaxSC
                                  06-14-2024, 03:49 PM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • ArkzG
                                  [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                  by ArkzG
                                  Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                  What I currently have available:
                                  - Model: FA506NF (2021)
                                  - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                  - Tools: CH341A programmer ready to use
                                  Does anyone have either a clean 2MB .bin dump of this model,...
                                  09-26-2025, 09:34 PM
