need bios
Asus u36SD rev2.1 bios
Re: Asus u36SD rev2.1 bios
post the bios backup hereDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
The bios posted here, the second post, is working but in 16 color mode and I have no option to change. I hope somebody can restore my original bios.
Thanks.Attached FilesComment
test and give noticeAttached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by kcp0085Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
Specs:
- ASUS TUF FA617NS-A16
- CPU: AMD Ryzen 7
- BIOS chip: Winbond W25Q16JVSIQ (2MB)
If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
Thanks in advance!-
- Loading...
