acer E1-531 Q5WV1 strange bios problem
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hello all
    i need your advice and guidance
    i got this acer E1-531 with board
    Compal LA-7912P Q5WV1
    intel platform with intel on cpu vga, no descrete
    problem was there is no image on screen, fans spins, led iluminated but nothing on screen
    as it happens, im fairly good with bios, so i flashed bios
    on web there are v1.xx and v2.xx but i did not know what version i have so i flashed v1 (both bios main 4mb, ec 1mb)
    it had post, give image but did not boot windoews since v1 does not support uefi boot
    so i made v2 bios and flashed
    it turned on, booted, everything seems fine
    but problem is next:
    if i enter bios and change ANYTHING and save and exit it wont post anymore??????????
    i tried web bios, dump and everything but always the same.. .
    any ideas???
    Im Back... sort of...
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: acer E1-531 Q5WV1 strange bios problem
    Might be The IC won't save it anymore if there was a change, so try replace the IC, or CMOS circuitry that has problem, just guess
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      what ec is on that board ?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        @meritosari
        tnx for idea, tried that today, same thing... using good known tested eprom
        @Djosla
        ENE KB930/KB9012
        have sch also if needed
        yesterday i got another pavilion dm4 with almost same symptoms
        flashed bios, worked for a day, after restart no image
        flashed again, powers on, displays "flashing boot block", reboots then no image again
        similar platform, intel cpu with vga, no descrete
        guess im on a row of bad luck :/
        could it be bga on pch/nb?
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          kb9012 ENE ? its command line programmed ..you will have some problem with that , Dycc found a solution for that , try to speak with him
          • Djosla
            • Dec 2012
            • 246
            • Montenegro
            KB9012 has 128 kb eeprom memory inside and you need special programer...i had problems with it on same motherboard...
            for dm 4,if it is amd, i belive you had problems with fch chipset...might be just bizzare coincidence with flashing bios with both laptops...i had case when just presing on top of the fch with finger ,laptop would work even for few days after...reball did not work...had to replace chipset...
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • zarabota
              Acer Aspire A717-71G - problem BIOS with keyboard
              by zarabota
              I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
              However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
              09-03-2025, 01:58 AM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • Wg188
              ACER Veriton Z4660G AIO bios help
              by Wg188
              I have an Acer veriton Z4660G all in one pc,
              Model: Z4660G-I5850H1 (VZ4660G_W)
              Need bios dump and schematic would save my life !
              to make a long story short I bought this all in one used
              with a broken lcd, with the objective of making a custom desktop out of it
              ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
              06-17-2023, 02:20 PM
