PLS I need asus X550C BIOS
  • kadi144
    • Aug 2015
    • 690
    • algerie
    The number board is
    x55occ main board
    rev 2.0
    pcb made in china
    i waithing
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: PLS I need asus X550C BIOS
    MB: Asus X550CC Rev: 2.0
    EC: ITE IT8517E HXA
    Flash: Winbond 25Q64FVS1G SOIC-8 (AMI Aptio)
    working dump.
    • kadi144
      • Aug 2015
      • 690
      • algerie
      not working sir
      the original working power but no data
      and wour dump mr imranromi no working power
      • kadi144
        • Aug 2015
        • 690
        • algerie
        not working sir
        and your dump mr imranromi no working power
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          BIOS Asus X550C try this one if ok bios reply me.
          • ridamouh159
            • Nov 2014
            • 365
            • maroc
            danke imranromi
            it s working data but there an problem
            when i put power the screen go direct to bios setup and to restart still the same
            i think that the problem bios
            • dj_ricoh
              • 2073
              • uk
              NO!
              that`s UEFI bios i think.
              Try to disable SECURE BOOT and and disable UEFI and go for normal boot with USB or optical priority .
              • ridamouh159
                • Nov 2014
                • 365
                • maroc
                make secure boot disable
                • kadi144
                  • Aug 2015
                  • 690
                  • algerie
                  danke imranromi and dj_ricoh
                  now alles ok
                  it working good
                  • vitortec
                    VITORTEC
                    • Feb 2016
                    • brasil
                    I recorded the bios laptop turns on and off then no video
                    • Meck
                      • Jan 2015
                      • 5
                      • Bosnia
                      • medinfo
                        • May 2016
                        • 328
                        • Morocco
                        Originally posted by ridamouh159
                        danke imranromi
                        1- Go to (Security) And Disable (Secure Boot)
                        2- Go to BOOT and Enable (Launch CSM)
                        3- Thanks
                        • sergio27992
                          • Oct 2016
                          • 7
                          • spain
                          Hi, I have tried all but none works correctly, the first one works but after 30 seconds the fan is full (i clean the me region), the second one when programming tells me it is too big (ezp2010) .
                          i upload my bios backup in case anyone can help me, i'm going crazy :S
                          thanks in advance.
                          • sergio27992
                            • Oct 2016
                            • 7
                            • spain
                            http://www.mediafire.com/file/gb1bug.../x550cc+bc.bin
                            • techman1025
                              • Jun 2014
                              • 497
                              Here
                              Let me know how it go's new clean me region merged with new update .
                              Start saving clean me region i will upload it you could use it when the laptop uses a HM76 chipset like your's so you would need to drop it in the fit tool and compare setting to the HM76 laptop you want to use it with save it now you have a clean me region laptop and then save it next time when needed you will have it i have many i had to rebuild one for your model in which i didn't have your model i had a clean HM-76 REGION
                              techman1025
                              • Browning55
                                • Mar 2015
                                • 28
                                • turkey
                                Thank you for Bios file is worked now my main board imranromi :*
                                • Marco_compucell
                                  • Feb 2012
                                  • 67
                                  • South Africa
                                  thank you
                                  • vcolaon
                                    • Sep 2014
                                    • 10
                                    • Croatia
                                    Thanks!
                                    My x550vc turns on with ''asus x550cc_ok_org'' dump but I don't have nvidia gpu and it crashes after standby.
                                    Anybody knows what do to? I'd appreciate it
                                    • notserforumlar
                                      • Oct 2016
                                      • 12
                                      • midilli
                                      thanks ^^
                                      • xapita_18
                                        • 5
                                        • SPAIN
                                        someone has bios x550ca
                                        mb x550cc rev 2.0
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
