need bios hp pavilion dv2-1209AU
  • HarryPK
    • Mar 2014
    • 212
    • barabai
    i need bios hp pavilion dv2 amd gpu. thanks
  • khaahk
    • Dec 2013
    • 830
    • Estonia
    Re: need bios hp pavilion dv2-1209AU
    download from hp
    http://ftp.hp.com/pub/softpaq/sp45501-46000/sp45822.exe
    extract with 7zip
    write rom file - depending on programming software the end gets dumped or cut to right size.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      i've download it and extract with rar, got file 1.064kb. i think should be 1.024kb for fit on to programmer. a dump question from newbie. have you any clue for cut the file for fit to the chip
      thanks in advanced
      • HarryPK
        • Mar 2014
        • 212
        • barabai
        thanks. i will try its
        • khaahk
          • Dec 2013
          • 830
          • Estonia
          Use hex editor, 1024kb is 10 0000 in hex. Sometimes need to compare with old dump to see if it has not been encrypted or if there is a an ec programcode also included, which should be separated from main bios. It could also be in the beginning of the bin file.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            backup old bios
            if this does not work, post old bios here
            Im Back... sort of...
            • HarryPK
              • Mar 2014
              • 212
              • barabai
              3x changed bios. laptop still not have disply. maybe ati gpu bad. can not continue..
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • survivalbloke
                Unable to extract bios file from Lenovo bios exectuable
                by survivalbloke
                I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                Code:
                "innoextract 7wcn38ww.exe"
                it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                The trouble I'm having is that I'm not getting the newly...
                06-12-2024, 07:55 AM
              • survivalbloke
                Unable to extract Lenovo BIOS file from installer
                by survivalbloke
                I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                How can...
                07-16-2025, 03:21 PM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
