ASUS k53sd rev 2.3 bios dump
  • Homer79
    • 13
    • england
    Has anyone got a bios dump for the 2.3 version. I can only find one for 5.1
    Regards
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: ASUS k53sd rev 2.3 bios dump
    try this
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      always backup old bios in case that you end up with 100% fan issue
      Im Back... sort of...
      • solevi
        • Aug 2015
        • Armenia
        Originally posted by gcomputers
        try this
        Thank you very much!
        • polytek
          • Dec 2013
          • 497
          • TUNISIA
          asus k53sd rev 2.3 ec bios
          hi,
          i need ec dump for this board.
          thanks.
          • polytek
            • Dec 2013
            • 497
            • TUNISIA
            Re: asus k53sd rev 2.3 ec bios
            steel waiting for a help;
            • highpulse
              i hate HP
              • May 2013
              • 1490
              • portugal
              there is no EC , only main , the small rom you see on board its for usb3.0 rom info . so therefore the only bios is the main bios of 4MB
              i just uploaded it .
              • polytek
                • Dec 2013
                • 497
                • TUNISIA
                thankyou for the info bro, and thanks for the dump.
                • alexanderrom
                  • May 2017
                  • Kazakhstan
                  Thank you very much) Very helpful)
                  • kero_kerokk
                    • Aug 2017
                    • 14
                    • egypt
                    thnx so mATCH
                    • fyaagoub
                      • Dec 2016
                      • 269
                      • maroc
                      Thank you very much
                      • rachid1271
                        • Jul 2014
                        • 5
                        • maroc
                        Thank you
                        • mathken330
                          • Sep 2020
                          • CANADA
                          Thank you.
                          • djharold
                            • Aug 2015
                            • 247
                            • COLOMBIA
                            thank you
                            • shakeelno1
                              • Mar 2017
                              • 16
                              • Pakistan
                              Thanks bro,,,, worked... ( -_-)
                              • Skrillex1989
                                • May 2022
                                • 16
                                K53E Bios Mainboard K53SD Rev 2.3
                                Hello
                                Can pls anybody Upload a .bin BIOS for
                                Asus K53E
                                Asus K53E-SX062V
                                Thx
                                • peste
                                  • Dec 2016
                                  • 13924
                                  • ROMANIA
                                  Re: K53E Bios Mainboard K53SD Rev 2.3
                                  Originally posted by Skrillex1989
                                  Hello
                                  Asus K53E
                                  Asus K53E-SX062V
                                  Thx
                                  post the original bios of the laptop
                                  • Skrillex1989
                                    • May 2022
                                    • 16
                                    the original bios is broken
                                    • peste
                                      • Dec 2016
                                      • 13924
                                      • ROMANIA
                                      post clear pictures with the white stickers in the memory area ram ..
                                      • Skrillex1989
                                        • May 2022
                                        • 16
                                        Ist that right ?
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
