ASUS k53sd rev 2.3 bios dump
  • Homer79
    • 13
    • england
    Has anyone got a bios dump for the 2.3 version. I can only find one for 5.1
    Regards
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: ASUS k53sd rev 2.3 bios dump
    try this
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      always backup old bios in case that you end up with 100% fan issue
      Im Back... sort of...
      • solevi
        • Aug 2015
        • Armenia
        Originally posted by gcomputers
        try this
        Thank you very much!
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          asus k53sd rev 2.3 ec bios
          hi,
          i need ec dump for this board.
          thanks.
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            Re: asus k53sd rev 2.3 ec bios
            steel waiting for a help;
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              there is no EC , only main , the small rom you see on board its for usb3.0 rom info . so therefore the only bios is the main bios of 4MB
              i just uploaded it .
              • polytek
                • Dec 2013
                • 496
                • TUNISIA
                thankyou for the info bro, and thanks for the dump.
                • alexanderrom
                  • May 2017
                  • Kazakhstan
                  Thank you very much) Very helpful)
                  • kero_kerokk
                    • Aug 2017
                    • 14
                    • egypt
                    thnx so mATCH
                    • fyaagoub
                      • Dec 2016
                      • 269
                      • maroc
                      Thank you very much
                      • rachid1271
                        • Jul 2014
                        • 5
                        • maroc
                        Thank you
                        • mathken330
                          • Sep 2020
                          • CANADA
                          Thank you.
                          • djharold
                            • Aug 2015
                            • 242
                            • COLOMBIA
                            thank you
                            • shakeelno1
                              • Mar 2017
                              • 13
                              • Pakistan
                              Thanks bro,,,, worked... ( -_-)
                              • Skrillex1989
                                • May 2022
                                • 16
                                K53E Bios Mainboard K53SD Rev 2.3
                                Hello
                                Can pls anybody Upload a .bin BIOS for
                                Asus K53E
                                Asus K53E-SX062V
                                Thx
                                • peste
                                  • Dec 2016
                                  • 12976
                                  • ROMANIA
                                  Re: K53E Bios Mainboard K53SD Rev 2.3
                                  Originally posted by Skrillex1989
                                  Hello
                                  Asus K53E
                                  Asus K53E-SX062V
                                  Thx
                                  post the original bios of the laptop
                                  • Skrillex1989
                                    • May 2022
                                    • 16
                                    the original bios is broken
                                    • peste
                                      • Dec 2016
                                      • 12976
                                      • ROMANIA
                                      post clear pictures with the white stickers in the memory area ram ..
                                      • Skrillex1989
                                        • May 2022
                                        • 16
                                        Ist that right ?
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • kodox
                                          Asus ExpertBook B1400CB Bios Dump Needed
                                          by kodox
                                          need original bios dump, original bios has flashed by other technician before me.
                                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                          unit info:
                                          Model: Asus ExpertBook B1400CBA-0711A1235U
                                          S/N: R6NXNZ006657238
                                          CN: 7F6F
                                          Mainboard Code: B1500CBA R2.1...
                                          08-16-2025, 12:20 PM
