acer d270 bios needed.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello guys. good day
    no power indicator. no 3.3 v and 5v alws.
    no shorted coil
    i just want to try bios first.
    tnx.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: acer d270 bios needed.
    if its aspire one d270 this should be it
    if not, provide more info
    Im Back... sort of...
    • rickybucalan
      • May 2013
      • 322
      • philippines
      tnx but it does the same..
      i checked PU3 and here is my voltage reading.
      pin
      1. 1.0 v
      2. 0v
      3. 2v
      4. 0v
      5. 0v
      6. 0.4v
      7. 0v
      8. 3.3v
      9. 5v
      10. 0v
      11. 0v
      12. 5v
      13. 5.9v
      14. 0v
      15. 0v
      16. 19v
      17. 5v
      18. 3.3v
      19. 0v
      20. 0v
      21. 0v
      22. 4.7v
      23. 0v
      24. 0v.
      Is that faulty?
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        change pc58, its OVP
        • rickybucalan
          • May 2013
          • 322
          • philippines
          what thats means?
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            over voltage protection
            try replace pc58 with tantalum, not solid caps
            look datasheet rt8223p
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              pin
              1. 1.0 v
              2. 0v
              3. 2v
              4. 0v
              5. 0v
              6. 0.4v
              7. 0v
              8. 3.3v
              9. 5v
              10. 0v
              11. 0v
              12. 5v
              13. 5.9v
              14. 0v
              15. 0v
              16. 19v
              17. 5v
              18. 3.3v
              19. 0v
              20. 0v
              21. 0v
              22. 4.7v
              23. 0v
              24. 0v.
              Is that faulty?
              lx gate +3vpcu rail its high, usually i try change that caps, and that works
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                agree with you meritosari
                PC58 cap issue . replace it
                • rickybucalan
                  • May 2013
                  • 322
                  • philippines
                  [QUOTE=meritosari;564629]over voltage protection
                  look datasheet rt8223p[/QUOTE
                  tnx would try thati just need to find 220uf 6.3v.
                  just to ask can i used 227uf 4v?
                  tnx.
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    [QUOTE=rickybucalan;564856]
                    tnx.
                    you can just use it for test . it can work . but use TANTALUM as meritosari said .
                    • lezsimply
                      The Wanderer
                      • 659
                      • Philippines
                      you cannot. its ok to go a little higher but dont go lower.
                      • rickybucalan
                        • May 2013
                        • 322
                        • philippines
                        [QUOTE=dycc;564888]
                        ok. yes its tantalum caps.
                        what if i put 2pc in parallel 107 uf 6v. could it be possible?
                        tnx.
                        • rickybucalan
                          • May 2013
                          • 322
                          • philippines
                          tnx u bro pwede kaya un?
                          • rickybucalan
                            • May 2013
                            • 322
                            • philippines
                            i already found one 227uf 6v but does the same now i lost 5v on pin 12.
                            pin
                            1. 1.0 v
                            2. 0v
                            3. 2v
                            4. 0v
                            5. 0v
                            6. 0.4v
                            7. 0v
                            8. 3.3v
                            9. 5v
                            10. 0v
                            11. 0v
                            12. 5v 0v
                            13. 5.9v
                            14. 0v
                            15. 0v
                            16. 19v
                            17. 5v
                            18. 3.3v
                            19. 0v
                            20. 0v
                            21. 0v
                            22. 4.7v
                            23. 0v
                            24. 0v.
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              I look at the picture, you have to install the capacitors with the wrong polarity position. look more carefully, coil its positive rail.
                              maybe you have broken that tantalum again, i hope not more damaged the other components
                              • meritosari
                                • Oct 2010
                                • 774
                                • Indonesia
                                info:
                                • rickybucalan
                                  • May 2013
                                  • 322
                                  • philippines
                                  info:
                                  oh man i'm so stupid.
                                  but thanks GOD it still working after i return to proper position.
                                  thanks to you meritosari.......
                                  • meritosari
                                    • Oct 2010
                                    • 774
                                    • Indonesia
                                    np. I'm glad you made it
                                    • String2016
                                      • Nov 2015
                                      • 2242
                                      • philippines
                                      thanks for this info meritosari i solved the netbook with this with the same problem
