how to extract the bios from this application?
  • inspirim
    • May 2013
    • 287
    • Italy
    need to reprogram the bios but unfortunately on the manufacturer the bios is integrated in this application attached, I need the .bin file you can help me?
    thanks to all
  • ameixoeiro
    • Oct 2014
    • 17
    • Portugal
    Re: how to extract the bios from this application?
    If you could make a copy from another and same model toshiba motherboard it would be so much easier..
    Could you tell us what model are you looking for?
    • R_J
      • 9609
      Is this the file you need? its the only .bin file
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        whit uniextract the .exe contain those files, there is a bin file but you check if it right for you.
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          on badcap server....
          • ameixoeiro
            • Oct 2014
            • 17
            • Portugal
            You can also open the provided zip file with winrar oror another compression tool, but that bin file is too small to be the bios file.
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              Which hardware refers the bios ?
              • inspirim
                • May 2013
                • 287
                • Italy
                I tried the attached file but it does not work the notebook does not turn on while the old man, the bios that I need is a toshiba
                model: tecra Z40-A-119
                thanks to all
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  Did you make dump of the old BIOS? Post it if you did. It might be useful in finding a match in those extracted extracted files.
                  • inspirim
                    • May 2013
                    • 287
                    • Italy
                    here is the file you saved, I urgently need to remove the password from this notebook
                    • marcellodj
                      • Nov 2010
                      • 99
                      If i remember bios pw on toshibas is NOT stored in the bios, but into KBC.
                      Find a named Pad JRSTxxx near RTC battery, or under ram slot (remove mylar if present)
                      then Remove AC-Power + Main Battery, short Jumper continiously and plugin AC-Adapter + press Powerbutton in parallel, wait for about 5-10 seconds.
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Usually pasword on older toshiba's is stored on more than one place (not only KBC). Even if you flash a new bios you will not succeed.
                        • sanehdeep2012
                          • Oct 2013
                          • 139
                          • india
                          If laptop Having two bios like main and kbc bios, then you cant extract the bin file from file downloaded from manufecturing site,
                          you have to take a dump from working laptop , or arrange the dump from another person who is having that,
                          • balobi
                            • Jan 2015
                            • 88
                            • phillippines
                            how to extract toshiba exe file?
                            • to5it0
                              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                              by to5it0
                              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                              I have opened the laptop and identified the main BIOS chip...
                              10-24-2025, 01:35 AM
                            • survivalbloke
                              Unable to extract bios file from Lenovo bios exectuable
                              by survivalbloke
                              I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                              Code:
                              "innoextract 7wcn38ww.exe"
                              it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                              The trouble I'm having is that I'm not getting the newly...
                              06-12-2024, 07:55 AM
                            • survivalbloke
                              Unable to extract Lenovo BIOS file from installer
                              by survivalbloke
                              I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                              I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                              How can...
                              07-16-2025, 03:21 PM
                            • Citymin
                              by Citymin
                              S/N : 5RNK9FFT70...
                              08-05-2025, 05:12 AM
                            • m1ch43lzm
                              Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                              by m1ch43lzm
                              Hi everyone
                              I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                              Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                              Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                              There's also an extra OTP Secu.R...
                              09-06-2025, 05:47 PM
