Bios dump for Lenovo G450
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Good day everybody. Do you have bios file for Lenovo G450. Problem is no power after pressing power button. No short or heating components. power button has 3v present. thanks very much
    PS,
    I tried downloading bios from website but its 2095kb in size.
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Re: Bios dump for Lenovo G450
    anybody got one? thanks
    • khaahk
      • Dec 2013
      • 779
      • Estonia
      What stops you from cutting the end off from the file. Compare the dumps...
      • degutji
        • Dec 2012
        • 173
        • Indonesia
        Try this
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          Thanks very much degutji. I'll try this tomorrow and update you if its ok.
          • rajeshkumar
            • Oct 2014
            • 44
            • india
            update soon
            • rajeshkumar
              • Oct 2014
              • 44
              • india
              Originally posted by degutji
              Try this
              hiiiiiiiiii itssssssssss work dud
              • Andyservo
                • Jun 2013
                • 152
                • Indonesia
                thank you...
                • AHmad_Salal
                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                  by AHmad_Salal
                  Hello all,
                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                  11-28-2023, 05:28 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • hyperwood
                  [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                  by hyperwood
                  I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                  The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                  I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                  āœ… What I need:
                  • A working 2MB BIOS dump
                  • Matching NM-E471 Rev. 2.0, e.g. JY575
                  06-25-2025, 02:28 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Joluvillas
                  Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                  by Joluvillas
                  Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                  06-18-2024, 10:35 PM
