Asus A53B
  • vinkos
    • Jul 2013
    • 51
    • Netherlands
    Asus A53B
    MOBO - LA-7322P does not start at all just no sign of anything.
    I did check voltage and i have on start button 3,3 volt > 5,00 volt and 18 volts
    witch is as should be .
    I guess bios might be a problem !
    On asus page is bios well to download but with size of 4MB .
    I need bios dump for chip because size of chip is only 2 MB !
    Also any other idea of possible problem is welcome !
  • raihan
    • Feb 2016
    • 41
    • Bangladesh
    Re: Asus A53B
    2mb dump
    • muhamad.sh
      • Apr 2017
      • 6
      • turkey
      Re: Asus A53B
      thank u my friend
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Re: Asus A53B
        • Techtiger
          • Oct 2014
          • 1601
          • france
          Re: Asus A53B
          • abbassink
            • Aug 2015
            • 83
            • iran
            Originally posted by raihan
            Re: Asus A53B
            2mb dump
            working for me thanks
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
