Asus A53B
  • vinkos
    • Jul 2013
    • 51
    • Netherlands
    Asus A53B
    MOBO - LA-7322P does not start at all just no sign of anything.
    I did check voltage and i have on start button 3,3 volt > 5,00 volt and 18 volts
    witch is as should be .
    I guess bios might be a problem !
    On asus page is bios well to download but with size of 4MB .
    I need bios dump for chip because size of chip is only 2 MB !
    Also any other idea of possible problem is welcome !
  • raihan
    • Feb 2016
    • 42
    • Bangladesh
    Re: Asus A53B
    2mb dump
    • muhamad.sh
      • Apr 2017
      • 6
      • turkey
      Re: Asus A53B
      thank u my friend
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Re: Asus A53B
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Re: Asus A53B
          • abbassink
            • Aug 2015
            • 83
            • iran
            Originally posted by raihan
            Re: Asus A53B
            2mb dump
            working for me thanks
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • lrouw84
              Asus vivobook s510ua bios changed to x510un
              by lrouw84
              Hi there,
              I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
              I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
              01-28-2023, 01:31 PM
