Asus A3e No Boot(Bios Program Problem .203)
    Hi
    i Have problem with Asus A3e no Boot issue(Power On But No LCD Display And No VGA Display )
    Laptop Working But After Change Power Button --> No Display And No Boot
    First I Want Program Bios , I Using Tni5000 Programmer , Bios IC Is PIC16C54C .
    I Can Read Data From IC And Many Of The Data Is Zero
    My Problem Is Bios File Format ".203" And The Programmer Can Not Program It.
    How I Can Program Asus A3e By .203 File Format(I Can Not Find BIN Or Rom Format)
    http://support.asus.com/download.asp...en&m=A3E&os=17
    Regards
    Re: Asus A3e No Boot(Bios Program Problem .203)
    just ask good guys for bios dump :-)
      That pic is a controller for charging battery, the bios should be in PLCC32 housing.
      Rename the extension from .203 to .bin, find the correct bios chip and you're good to go.
        Thanks For Info
        I Can Not Find Bios IC In Schematic , Just I Find bios battery backup On Motherboard And PIC16C54C was near the battery
        But Yes , In Schematic PIC16C54C Is For charging battery controller
        Tomorrow I will look further On MotherBoard.
        Attached Schematic Maybe Someone Can Find Bios IC.
        greetz
          u43 is bios. On board it shold be easy to spot it.
            Thanks Brother , I Find It And Program It.
            But The problem still exist
            NorthBridge and South Bridge are hot now!
            Northbridge fan spins slowly at first But after 2 seconds NorthBridge fan is spinning too fast !
            How can know the problem is from the NorthBridge or SouthBridge ?
            Greetz
              The problem was resolved by replacing the South Bridge Chip.
              Regards
