k53sv weird bios issue
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    og guys , received this machine from another store , complaining computer not turning on ..
    i put in the bench and noticed , its turning on , flicks the screen on the on off moment but nothing else.
    first thing , cheked bios . found a big problem when reading it , someone tryed to make a update somehow (think on windows ) and found that the file insyde the ROM is for k53SJ so not compatible .
    manwhile i found at 1bios a dump for the k53sv , but version 324 (something that not even exist on the asus site (maximum there is version320) even like this i reflashed the bios with this dump and ok , it works fine and let the machine go to windows . but when entering in windows , resolution is always at 640 and 16 colors ... noticed that both drivers were not instaled HD intel and NVIDIA (but even like this should be pretty bether the image) i isntaled both drivers , restarted but the same 640resolutio by 16 collors.
    now 2 things i think are possible this was the problem and or client or the store tryed to upgram bios to see if with would solve the problem or this dump is not the 100 correct for this machine .
    so my question is .
    i can deliver here 3 dumps for someone can help me out figuring something
    that would be ,
    k53sv 324 version found 1bios.ru
    computer dump (with the wrong model bios but it have the EC rom in the beggining.
    and K53SV version 320 downloaded from asus but its 2600kb .
    so resuming if someone know how to cut /repair bios ,. culd anyone insert the k53sv 320 version instead of the bad 324 version ? i think the EC part of the code of original computer bios is ok , only the mai part is not correct , if someone can update the correct part into the original dump would be very happy with it . if someone can help me out doing this , before i start attacking video chips etc.
    1bios.ru bios zip if the dump found online the 324 version ,
    the outher zip its the version from asup + my dump frmo my computer.
    thk in advance
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: k53sv weird bios issue
    well its done , found here a 215 version , ad it works on computer then i run easyflash i instaled the 320 version , but this is for sure a grafic problem , still persist the 640 resolution + 16 colors
    will provide further infos later on
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3597
      • slovakia
      if u install gpu driver system goes to BSOD?
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        whatsoever i do , deinstall , dactivate , whatsoever the HD intel or NVDIA does always the same in safe more or normal mode
        cannot change reslution and collors . barely almost imopssible to work .
        even tryed starting a new install , but the same happen once the first windows show up
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          btw never appeared any blue screen , simple i cannot change resolution , and colors as well
          • techman1025
            • Jun 2014
            • 497
            Hi
            Remember you can't use a bios dump from another intel machine it will have Me region problem like shutting down fan's might be racing ...so if it's a full update then no problem you will be sent to go but if it's a half update then you could merge with the original file and be set to go...BUT if the original file has a dirty me region you will have all sort's of problem and the only fix is a new clean full dump ..if not able to get one then use a dump from the exact machine and you need to rebuild the Me Region using a new clean me region from any company like acer ,toshiba, hp and using the same plate form and using the intel fit tool to rebuild it compare it with the original file then all you need to do after rebuilding it is to cut out the old ME and pasting the new in using a text edit program like HXD . So trying to locate where the old me region start is easy in text edit open original file and scroll down viewing the right side looking for Header $FTP compare it with the header of the new me region you just did and write down the size of it and high light the old at the starting point and the ending of the the new file delete it then go hi light the whole new me region copy it and past in the old original file make sure the size matches the old save changes like NEW_ME_.BIN done ....remember once a computer boots it married to that laptop or computer and if use in anther machine you will have to rebuild again with the intel fet tool tool starting at version 5,6,7,8,9 so if your chipset is a HM55 you use that tool intel fit 5 all amd model have no me region only Intel models so no need for dirty Me region on a AMD plate form ...if you use the original file and merge it with the update and as long as the original file has clean me region you will be set to go...on apple computers you can't decrypt and update so you could use and other dump and rebuild the me region and be set to go REMEMBER once that computer is booting it marries the computer so when you make a clean dump save it as clean and you could always use it has so . HOPE THIS HELPS PS IF YOU NEED ME ...ps if you need me to fix your file shoot me a message
            Techman1025
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              well Robert for sure i will need your help with the bios issue , you're to advanced in this area to follow you , maybe after some good training i can follow you but in this moment , im not capable .
              so if you can help , shot me a mssage and we speak , let me know wich files , you need .
              thk ina dvance
              btw , computer keep doing same thing only in windows , image is 640 pixel resolution , 16 colors , and i cannot change does values .
              HELP
              • dj_ricoh
                • 2073
                try linux(ubuntu)
                if it works then its the driver problem
                • highpulse
                  i hate HP
                  • May 2013
                  • 1488
                  • portugal
                  dj ricoh , it happens also , when trying installing windows wehen you choose if you want 32 or 64 bits install , so it cannot be drivers problems ... must be something with bios or any one of the chipst (gpu or HM )
                  • dj_ricoh
                    • 2073
                    with linux?
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      also , not sending nothig to external screen , well lost my ubuntu cd , must donwlaoded and records another one ... but i don't really think its a windows thing .. even when disabling video card , one or another it should at least let me change resolution or colors , something thats is not been allowed
                      • techman1025
                        • Jun 2014
                        • 497
                        Hi
                        Just upload original i will fix it for you .
                        Techman1025
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          i there techman , chek above , my first post, there is the DUMP K53SVAS320.rar (2.70 MB, 0 view
                          there is a folder with 2 files dump.bin was the bios bin that was in the ROM .. the outher file is the 320 version found at asus site for k53SV -
                          alltough i remember you that the main part of the bios is not correct since someone try (in the outher store or client) to flash with k53SJ and obviously machine wouldn't give image or somethimes not boot at all . so do your miracles to fix the ME region and put the latest version that is on the site .
                          Let see if it fixes something.
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            meanwhile still strugling with many test , just want to try a clean bios before going further with reworks on GPU
                            • dj_ricoh
                              • 2073
                              omg stop it and dl ubuntu >.<
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                its downloading mate its donwloading
                                • dj_ricoh
                                  • 2073
                                  let me tell you my story with my new video card.
                                  got my self a gtx 970 4gb mem
                                  do you understand that i could not install the video card?
                                  and after 1 hour i was planning to tell the seller from ebay you $%£$%£@$R you gave me a broken video card. i remember f k me its got a CD ...
                                  ofc even with the cd it barely install it.
                                  its ok its working fine flowers and farting rainbows but its the same deal with that video card.
                                  i got a big 18.4 sony vaio notebook its the same crap i manage to find the driver after half a hour.
                                  again install ubuntu and see if its detecting on Console
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    recorded on cd , booting up now
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      well ubuntu seems fine .alltough gave a I/= error with a few weird lines on screen (like grafical issues) but , i pressed enter and let me chek , image is more stable now , let me see truelly insyde ubuntu is still finishing booting
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1488
                                        • portugal
                                        well meanwhile booting , when it appear soe warning and stuff to carry on , i notice some flickers and lines , but after passing it , all seems fine . im on ubuntu live version running on CD . image seems stable .. but altough i cannot chek for the hardware controlers.
                                        weird very weir
                                        no external altough
                                        • bestrafer
                                          Lenovo L460 LAN issue after BIOS dump flash
                                          by bestrafer
                                          Hello everyone.
                                          I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
                                          BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
                                          But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
                                          Could someone point on a direction...
                                          01-31-2023, 01:14 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
